Results 1 to 20 of 20
    May 2008
    mga bro! i just noticed yesterday na yung right wheel sa front ng ek ko mejo naka labas compared sa left side... if you would look at it from the front view mejo litaw yung outer portion ng tires sa right side.... the whole wheel is somewhat offset pero direcho lang sya (hndi nakaliko or something). what are the possible cause and cure? alignment lang ba to? or is there something i should replace na? thanks in advance!
    May 2007
    Quote Originally Posted by tek View Post
    Pareho ba ang sizes ng gulong mo, baka malapad yong isa.
    All things considered, check your suspension, trailing arms.
    Same thing happened to me! Car hasn't been used for more than a year tapos I noticed the same thing with the front tire (passenger side). Hinayaan ko kasi na flat yung front tire (driver's side) for almost a month. Baka kaya nasira
    May 2008
    when was your last wheel alignment? baka matagal na. pantay ba ang upod ng gulong? parang alignment lang ang kailangan para sa akin. one more thing, tumigas ba manibela?
    May 2008
    Quote Originally Posted by berting101 View Post
    just had it aligned 2days ago... ganun parin...
    yup... actly kabibili ko lang ng bagong gulong last week... so bagong bago pa
    hmmm... what i noticed is that mas magaang sya ikabig sa left(driver side) compared sa right(passenger side... kung san nakaalsa yung gulong na side) pero pag binitawan yung steering wheel wala naman kaibig... direcho lang...
    May 2008
    Quote Originally Posted by v6dreamer View Post
    yup! same brand same size (205/45/17)
    Oct 2007
    hindi ba tabingi ang mukha, baka suspension problem kasi........
    sir hindi kaya mas mataas lang yung right than the left kaya sa tingin parang mas nakalabas yung right side?
    try niyo sukatin kung magkaiba talaga... kasi sa ek natin talagang mas bagsak ang left side sa right. normal po ito...
    May 2008
    Quote Originally Posted by archie123456789 View Post
    thats what ive heard and noticed... kaya nung nagpalowered ako pinaputulan ko yung sa right side ng konti para pantay... hndi kaya yun ang cause?
    ang tanong pantay ba pagkaputol? usually kung putol mo kasi right, ccounter pa din yung left. ginawa ko na din dati yan sa EK ko with adjustable springs.
    to cut the story short... measure ako then adjust pero bilang hindi ulit pantay... bale adjust ako right side the yung likod naman na left ang higher... actually theres no remedy for the prob unless sobrang tiyaga magadjust. yung friend ko sakto pero took him 5-6 hours para lang pumantay.
    usually parang mas nakalabas talaga tignan yung sa right than the left... measuring tape mo yung layo ng wheel sa fender. dun mo makikita kung ano talaga... pero feeling ok lang yan. wala naman ata ginalaw except for the mags and springs di ba?
    May 2008
    hmm... can we post pictures here? if so, ill try to take a picture of both left and right side... then tell me if that's normal....
    btw hndi halata or close to no diff pag tiningnan from the top view (sa fender) ... but there's an obvious difference when you view it from the front (sa bumper)
Help... Nakalabas yung isang gulong
