Results 1 to 10 of 39
- Sep 2006
- 2,746
April 6th, 2015 09:21 PM #1The car is a '96 Corolla. Before sending the car to a mechanic, I wanna ask you guys which part do you think is the suspect for the noise.
The lagutok is heard during:
- (car at full stop) then turning steering wheel either left or right
- (car is slowly running/moving) towards a hump or uneven surface (note: there's still lagutok even if steering wheel is not turned during these times)
- (car at full stop) i went out and try bouncing/yanking the car up and down
I'm confused if the problem is in the steering mechanism or the suspension system itself. Need your expert advice. Thank you very much guys!
April 6th, 2015 09:31 PM #2
My wild guess: Bearing of the shock mounts? When you open the hood, this part is located on the corners. The shock absorbers are connected to this. May bearing yun to make turning easier. May prize ba yung makahula ng tama?
April 6th, 2015 09:48 PM #3
There could be a thousand causes but the most common, given the symptoms you provided, would be the left and right tie-rod end and/or rack-end joints (aka inner tie-rod).
You can diagnose it if you want: https://youtu.be/brI2feYiEi8
- 54,290
April 7th, 2015 12:17 AM #5- - - - - - - - - - - - - - - - - - - - - -
that's not difficult to find out. and yes, any of them suspension parts can cause your symptoms.
a half-decent mechanic can find out, just by manipulating the suspension parts while the car is lifted.
we can keep guessing here, or you can bring the car for checking tomorrow.
but do ask the prices of the replacements, before you allow them to baklas the car.
among the non-oem brands, i like 555 for their reliability.Last edited by dr. d; April 7th, 2015 at 12:19 AM.
- Sep 2006
- 2,746
April 7th, 2015 06:13 PM #6Thank you very much for the tips guys! Well appreciated.
I brought the car to the mechanic this morning, the parts that were replaced are 2 ball joints (maganit na), 2 inner tie rods (matigas na yung "play"), and 1 shock mount (punit na). I'm not sure which part talaga nag cause ng noise, though im betting yung inner tie rods ang cause ng ingay.
Medyo namahalan lang ako sa wheel alignment kase it needed camber adjustment, i was expecting normal alignment lang kase. Anyway, ok na ang kotse, thanks again people!
- Jan 2011
- 99
April 13th, 2015 11:36 AM #7
sir ask ko lang din kahapon kasi nagchange oil ako ng oto ko first time diy change oil napansin ko lang
na walang tie rod yung sa front driver side ko tapos yun kabila meron Honda city exi 97 po pala tsikot ko
ang question ko lang po ay pede ba i diy yun paglalagay ng tie rod outer tie rod siya sir
or kelanga dalin sa mekaniko para sila na ang magpalit .,. saka magkano ba pares ng tie rod..??
kelangan ba dalin ko yun isa tie rod para may basihan ng sukat or iisa lang ng sukat ..
nagsearch ako sa youtube pede siya diy kaya
lang after ba nun kelangan din i align yun or camber kasi d pantay kain ng gulong ko .. thanks
- 54,290
April 13th, 2015 11:58 AM #8- - - - - - - - - - - - - - - - - - - - - -
everything is DIY-able, if one knows how. i know of people who overhaul their engines... dala lang nila sa machine shop for the machining, so's they don't have to buy expensive machinery..
tie rods.. yeah, they're not difficult to replace..
so you've been driving around minus a tie rod?? lucky you, buhay pa kayo ng kotse mo.. heh heh.
yes, it is best if you have alignments checked, everytime you kumpune the suspension..
April 13th, 2015 01:41 PM #9
- Jan 2011
- 99
April 14th, 2015 03:25 PM #10yes sir ., napansin ko lang nung sunday nag DIY change oil ako tapos chineck ko mga pang ilalim at nakita ko nga
na isa tie rod lang ang meron which is passenger side .. 2nd hand ko lang kasi ito nakuha at first time ko nakita
under chassis niya so isa ren siguro yun kaya d pantay kaen ng gulong ko sa driver side at isa ren reason yun kaya marami kalampag which is palitin naren ang mga bushings at shocks ko .. yung pagreplace ba ng shock pede i diy ..?
meron naman ako mhihiraman na pang press ng spring eh.. para makamenos sa gastos ..
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
