I am planning to buy 15" mags for my VIOS 2009. My problem is the correct offset for the 15"mags, I might buy a wrong offset. What is correct offset would I buy? that will not grind on the finder and when it is fully turn?
sir try to check your manual for your stock wheel offset. if not indicated, follow this steps to know your stock wheels offset:
http://www.ehow.com/how_5021837_calc...el-offset.html
this will be used to determine what wheel size(i.e 16"/17") and tire combination you would like to replace. here is the link to give you additional info:
http://www.wheelsmaster.com/rt_specs.jsp
just fill-in the data requested and it will give you the wheel and tire combination..
HTH![]()
