Results 1 to 10 of 11
Unregistered user
- Jun 2003
- 1,122
September 29th, 2005 12:49 PM #1Hello i just want to ask if any of you guys know what might be the cause of this...
vehicle is a 2000 strada
My brake was perfectly ok, no problem of whatsoever but I decided that it was time to change the brake fluid; I had my mechanic bled it and poured new spcified brake fluid in the reservoir we are perfectly sure that we did it the right way because he was already a old mechanic and I did managed to supervise him while he was doing it having a chilton manual as my reference
What happend after the change in fluid the braking was ok but i noticed that when the engine is not fully revving the brake pedal tends to bottom out the same is also when traversing inclines or declines.
When on highways and when the car is running fast there is no problem of whatsoever "talagang malakas ang preno" it doesnt bottom out.
Here is a list in chronological order of what we did after encountering the problem:
1) bled it a few more times i think we already used up 2 liters of brake fluid
2) repaired the brake master cylinder with a repair kit
3) got a new brake master cylinder assembly including the plastic cup
4) adjusted the load sensing valve (LSV)
5) replaced the LSV
6) replaced the brake pump attached to the back portion of the alternator including the alternator with a new one.
I already spent more than 50k for the damn brake system and up to now the problem aint solved yet in fact almost the whole brake system was replaced ang natira na lang ay yung hydrovac but we are positive that this isn't the problem.
any of you guys encountered this?
thanks in advance for the help
September 29th, 2005 01:22 PM #2
May check valve ba from the engine to the hydrovac ang Strada? Sa benz kasi pag nangyayari yan yung check valve may kasalanan
Unregistered user
- Jun 2003
- 1,122
September 29th, 2005 02:51 PM #4theveed
thanks i did check yes it has one i will ask my mechanic to check it later
bluebimmer sad to say yes inabot na nga ng ganun
up ko lang baka may ibang inputs
September 29th, 2005 03:26 PM #6
grabe yung 50K for break repairs. mukhang OEM lahat ang ginamit mong replacement parts. ako noong nasira ang hydrovac ko (for toyota hilux) I went to evangelista and got a surplus for just 2.5K (original is 10 - 12K) and replaced my brake master cylinder with a replacement one (bago) for only 2.8K. nagbo-bottom out ang brake pedal ko noon dahil yung fluid pumapasok na sa hydrovac. up to now (3 years) di pa nasisira yung surplus hydrovac ko ;)
September 29th, 2005 11:33 PM #7
Sa Vitara yung brake master din ang problema when we got it. No leaks ended up on the garage floor because all the leaking fluid went into the hydrovac system.
A new master was Pnp 8K. Well worth it. Kaso bopols yung mga nag-install. Ang mahal pa naman ng labor (Php 1,000.00) ata kasama kabit ng new pads.
Pinatawag ko pa si cousin Ferdie ni afrasay to rectify the botched install (Php 200.00 lang siningil samin).
Advice ko sayo, get another mekaniko.
BANNED BANNED BANNED
- 3,790
September 30th, 2005 04:48 AM #8Sayang, sa 50K maigi pang sa casa mo ipinasok...hindi na magkakalayo ang presyo...anyways, in my limited experience ang major cause lang ng bottom-out ay presence ng hangin sa linya....ang hindi ko ma-gets ay mukhang ibinleed nyo naman ng tama (naka 2 litro ka nga diba...taka lang ako, kami hindi man makaubos ng 500ml sa bleeding). Hindi kaya me problema sa bleeding process?!? kasi unang-una nagreplace ka lang naman ng brake fluid sa simula.
the air pressure assisted hydrovac could also be a cause, na pepressure test din yun linya yata kung enough pa ang pressure coming from that air line...
my 2 cents.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 5th, 2005 03:32 AM #10
2000 Strada.
Did you check the hose from the alt/vacuum pump to the hydrovac? It could have a small leak somewhere.
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
