Results 1 to 19 of 19
    May 2009
    Help mga gurus...
    Kapag nag-brake ako meron sound sa harap na gulong, driver side, parang kumakamot na sound, maririnig mo lang talaga siya kapag umapak ako sa brake... pinapalitan ko na brake pads at pina-reface, nawala siya for a while, then bumalik ulit, binaklas siya ulit, pati caliper, may konting tagas kaya nagpalit ng kit (mga goma), nawala ulit, pero after a while balik na naman tunog niya...
    ano sa tingin nyo mga bro?
    thanks in advance!
    Jan 2008
    baka bearing
    May 2009
    baka bearing
    bearing ng ano bro?
    matining ba yung sound? ano pads na pinalit? baka yung pads din masyado matigas kaya ganon.
    Nov 2007
    Quote Originally Posted by flakez View Post
    +1 on the brake pads, check the brake pads you installed, if it's too hard the sound will be there.
    May 2009
    Quote Originally Posted by ans_lim168 View Post
    mga bro, before OEM yung pads nung unang lumabas yung tunog, then nag-palit, after a while ganun na naman, then nag-palit ulit, after a while na naman, balik na naman problema.
    Feb 2009
    Quote Originally Posted by TheNaughtyCrew View Post
    Help mga gurus...
    thanks in advance!
    one common mistake of "mechanics" after a brake rotor/drum resurface: wash the newly resurfaced disc/drum with warm soapy water and dried before installation. the anatomy of their mess up, the cast iron dust on the disc/drum after machining gets stuck to the brake disc causing noise upon brake application. similar to cylinder bore honing or machining, it is required to wash the "new" surface with warm soapy water to remove abrasive dust from the surface
    Feb 2009
    Help mga gurus...
    thanks in advance!
    since you already had the discs resurfaced and the pads replaced, more than likely all you need is to (wet) sand your pads with 240 grit sand paper. the cast iron dust from machining has already sintered or glazed on the surface of the new disc pads. also check for backing plate or splash shield for contact with the disc
    May 2009
    *jick
    bro, lumabas yung problema nung tunog dati pa, hindi pako nagpapa-reface & palit ng pads, nagpalit at nagpa-reface lang ako as per advise nung mekaniko, pero after a while bumalik din yung problema...
    if reface ang problema, tutunog lang yun after ko magpa-reface at magpalit ng pads, plus dapat pati yung kabilang brake tutunog din, kaso yung driver side lang ang may tunog which is yun ang may problema before pa.
    Feb 2009
    *jick
    it will be difficult to search the origin of the noise you described when the vehicle is on the ground and in motion. try raising and supporting the front engine cradle, apply parking brakes and chock your rear tires. then run the front tires in gear while listening with a stethoscope. also, if you could describe the noise better with a comparable common noise, e.g.: scraping at high pitch, growling, moaning, grinding or intermittent chirping.
    if its moaning then let it be :D seriously now, apply silicon brake paste on one side of the brake pads between the thin plate and the pad, not the one in contact with the rotor.
    Feb 2009
    i apologize for the jargon. i used to work for general motors and they have used "moan" and "groan" interchangeably for a particular noise in the brakes. this happens when the transmission is in drive and the brakes are applied lightly allowing the brake discs to slip. similar falls true with manual transmission cars when the brakes are allowed to slip when the car is downhill.
Help... Brake Issue for my Honda Civic '96
