Results 1 to 8 of 8
    Would it be safe and still have good stability? I'm Planning to add hight on my Honda Civic 2002 VTI-S... Any idea?
    based sa experience, ok naman sya opinion ko lang to ha
    bad ata pag naging uneven na yung pag-sag ng rubber...
    Oct 2004
    Ok naman rubber spacers on coil springs sa rear, it gives an added ground clearance, be warned though on putting spacers in the front springs kasi baka bumigay agad shock mounting and it will throw off your alignment (mahirap ipa align after)plus mas magiging matagtag ride because of the compressed springs from the spacers
    May 2005
    okay naman ang spacers, you can choose pa the thickness depending on your needs
    Change stock fluid shocks to gas shocks.. you'll feel the defference at the same time it will maintain a good hieght to your car ksi masmatigas at masmatibay pa.
    thanks sa replies.. wala naman sira ang rear shocks and springs ko... plan ko lang maglagay, kasi i'll be putting 2 loads of Subs + Box. Baka kasi lumiyad ung car pag nalagay ko na..
    thanks sa mga comments.. now i'm ready to add hieghts..
    * emongedmund
    I'm planning to replace na din kaso la pa areps para dyan.. ubos sa sound system eh...
Help about Spacer on Springs/Shocks
