Results 1 to 6 of 6
    Nov 2011
    meron na ba shop na may suspension tester / shock absorber tester / side slip tester within metro manila (yung hindi LTO PMVIC/MVIS, kase kung PMVIC/MVIS puro testing lang, wala adjustment na magaganap kung may makita problema sa side slip test)?
    mas okay kase kung calibrated machine ang mag test ng suspension kaysa sa manual bounce test or leak test lang ang basis
    Jul 2013
    stock shock absorber cannot be adjusted.
    actually, I don't think stock suspension of normal cars can be adjusted.
    if a car fails the PMVIC's suspension test... better replace everything since pinakalas mo na rin
    i agree.
    if the car "fails the test", parts have to be replaced. arms, ball joints, bushings and shocks, i suspect.
    alignment lang ang puede i-adjust, but only after the worn parts are replaced.
    bring it to the MVIS. if it passes the test, then we have nothing to worry about.
    Nov 2011
    i agree.
    saw this sa internet, sa honda may suspension and side slip tester sila, sa toyota ba? tatanong ko bukas kung meron sa toyota
    yun lang sa honda ka presyo na ng MVIS ang suspension and side slip test
    Nov 2011
    repair shop sana hanap ko para ma adjust yung alignment na din on the spot, di tulad sa MVIS na puro testing lang
    Jul 2013
    Quote Originally Posted by jresperanza View Post
    this looks interesting. kaya lang shock absorber lang test nya.
    nice to have when buying a used car
    I also wonder if its calibrated to match PMVIC standards.
suspension tester
