Results 1 to 10 of 24
- Jan 2007
- 7
January 31st, 2007 11:08 AM #1This happened to me last Sunday... madulas yung daan, so nung nag hard brake ako (damn jeepney drivers sa bagong barrio caloocan) nagslide yung likod ng kotse to the left. Parang nagdrift pero in a freaky scary way. Inisip ko, umulan kasi kaya nagslide yung likod ko.
Pero this morning, approaching the camachile flyover at 40kph, napahard brake na naman ako (again, the U-turning jeepneys)... nagslide na naman yung likod ko. As in nag 90degrees slide yung kotse. As in slide sideways.
Both happened na nakatuwid lang yung manibela. Dati naman pag hard braking ay tuwid pa rin ako humihinto. Pero ngayun, freaky na. Pa-enlighten naman me. Thanks
- Nov 2006
- 299
January 31st, 2007 11:16 AM #3ano kotse mo? equiped ba ito ng abs? longitudinal split or diagonal split?
- Jan 2007
- 7
January 31st, 2007 11:21 AM #4Mitsubishi GSR po sya. So, wala pa ABS. Its like this, if Im going north and braked hard, yung rear ng car would slide to the left... after that, nakaharap na yung kotse ko sa East.
Is it still safe to drive the car? Im thinking pa-tow ako mamaya sa utol ko
- Apr 2005
- 40
January 31st, 2007 11:38 AM #5it is possible magslide kotse mo. this is one of the techniques in drifting para mag slide ang rear
January 31st, 2007 11:52 AM #6
Bro... baka naman pudpod na ang mga gulong mo? If not baka may problem na ang brake mo at parang uneven ang braking power distribution ng tsikot mo...
January 31st, 2007 11:59 AM #7
Check mo alignment, baka hindi tama yung tracking ng gulong. Check mo na rin brakes kung pantay ang kagat. Tama si Mazdamazda, check mo rin condition ng gulong baka pudpod na yan at nag hydroplane ka na.
Parang ganyan ang nangyayari kapag imbis na tumapak ka sa brakes, nag emergency brake ka using E-brake. Lalabas yung likod.
- Oct 2006
- 114
January 31st, 2007 12:04 PM #8carlo, di kaya kalbo na gulong mo or busog sa hangin?
suave lang sa pagbrake seguro.
pa diagnose mo nlang kaya muna for an accurate assessment.
and Welcome sa tsikot.
- Nov 2006
- 263
January 31st, 2007 12:38 PM #91.uneven wear on the brake shoes/pads
2.tire pressure is uneven on both tires
3.tire thread
4.uneven pavement
one of them or combination or all of em.
- Jan 2007
- 7
January 31st, 2007 12:57 PM #10guys,
thank you sa mga nagreply... Wala pa 3 months yung tires, kapapaalign ko lang 3 months ago. Just checked the tire pressure, 30 pa rin... Siguro sa brakes na.
Safe pa ba ibyahe ito? Super salamat talaga
high idle RPM at engine start
