Need advise Tsikoters.. Sumasayad yung gulong ko sa rear left fender mostly than the right.. My car is Corolla big body. Ano kaya meron problem.. Spring or Shocks? TIA
I have just replaced with 15in. rims w/ 195 x 55 series tires. it still have height clearance of about 3.5 in from fender.
In addition.. my car before was lowered (cut springs front & rear), then restored to stock springs (surplus) and is on stock 14in. rims.. Now, even total 3 persons lang sakay (2 in front + 1 at back), sumasayad kagad gulong sa fender even on small road bumps.
Your surplus springs are old and not as stiff as they used to be. That should be the culprit right there.
Most things that concern ride height usually are the work of springs.
Yes.. you are correct. The wheels are a bit off-set. The side of the tires are rubbing against the fender just beside the tire thread. I think if it had been 10mm less wider, should be no problem.
Is there any solution to this?
Help advise din po where to buy good springs.. how much din po?
Im located at Makati.
TIA.![]()
