Results 1 to 10 of 12
Heretic GuestAugust 9th, 2005 11:58 PM #1
I went to Petron Katipunan this morning for refuelling when the attendant asked me, "Ser, bombahan natin yung gulong nyo sa harap, mukhang manipis." I agreed but my front tires got a reading of 32 psi.
It is normal to have a higher psi reading when your tires are hot right? My tires are usually 30 psi when they are cool. Hot or cool, they look flat. What seems to be the problem?
My tires are 185/65-14 Kumho Optimo's, with 5.5" X 14" rims. My Matrix weighs 1,370 kilos.
August 10th, 2005 12:50 AM #2
Itsura or porma lang siguro ng gulong, in my opinion.
Kung tama naman yung inflation as recommended by your car manufacturer, I don't think that you should worry. Just the same case with my Goodyear Tires with specs (185/65R14) and with a pressure of 30 psi sa front and 29psi sa back (cold tires). I just follow the Owner's Manual of my car.
August 10th, 2005 12:58 AM #3
There are some tires kasi that look that way. I used to have a set of Toyo tires, that everone would comment that they are flat. The specs of the tires actually say that it should appear that way.
August 10th, 2005 01:54 AM #4
Yeah, some tires look that way.
But for 185/65-14 specs which isnt a low profile tire, it shouldnt look flat.
Hot or cool, hindi ba dapat 32psi? 205/50/17 ko is 32psi and 2psi below pressure, the *TPMS warning comes on.
*Tire Pressure Monitoring System.
August 10th, 2005 08:33 AM #5
ganyan din comment ng mga tao sa turanza na nasa 323. flat daw... then when i check it tama naman.
August 10th, 2005 08:39 AM #6
mukha nga lang siguro. minsan yung corolla namin ganyan din ang tingin ko. You will know naman if you are running on flat tire, lalo na kung sa harap.
August 10th, 2005 09:35 AM #7
Looks don't matter: if you have a good tyre and it contains the manufacturer-recommended PSI for the air inside it, you have nothing to wory about.
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 10th, 2005 10:02 AM #8depends on the sidewall design. kung matigas or malambot. the softer (more flat looking) it is, the better the ride.
August 10th, 2005 11:55 AM #9
The RS has "flat" looking tires... part of the reason for this is that the mags are also slightly too narrow for the tires. Maraming stock mags na ganyan. Narrow mags + wider tires means the sidewall angles out, and spreads out more when you put weight on it.
Xiaomi E-Car
