Results 1 to 7 of 7
- Dec 2014
- 3
December 10th, 2014 11:46 AM #1Mga sir tanung ko lng po,takbo po mga 60 pagnalubak nag wiwigle ung gulong sa harap,anu po kya problema dun,Mitsubshi L300 96 model po.
December 10th, 2014 09:22 PM #3
- Dec 2014
- 3
- Dec 2014
- 3
- Mar 2010
- 2,275
December 11th, 2014 10:17 AM #6Dalhin mo sa Zafra; ite-test drive nila ito at i-estimate yung papalitang parts...
- Apr 2009
- 429
December 11th, 2014 08:12 PM #7There are lots of things to check as the L300 has lots of linkages with its steering system
check the ffg:
- tie rod ends
- upper and lower ball joints,
- shaft link kit,
- repack or replace (if necessary) the inner & outer wheel bearings
- draglink if needs replacing (its joints are not replaceable so you have to change the whole thing if both joints are loose and shot)
- bellcrank - same as the dragling, if its joint is loose & shot you have have to change the whole thing)
- centerpost - this is the weakest link and probably a design flaw of the steering system as its plastic bushings don't last that long
*** the front suspension of the L300 is a PITA to maintain. We still have one in the stable. The "555" Made in Japan repl brand is a good brand
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
