Results 11 to 20 of 25
September 4th, 2010 11:34 AM #11
No. Always, always, ALWAYS put newer tires on the rear axle.
This is the advice of experts, the advice of tire manufacturers and the advice of car manufacturers. Without exception.
Whatever car you're driving, having bald tires in the back means a spin-out.
Trucks spin if they have bald rear tires. Jeeps spin if they have bald rear tires. Front wheel drive cars spin if they have bald rear tires (from personal experience).
Bald front tires? Braking distances get longer, but you can still stop. You have more understeer, but it's better knowing you have a lack of grip than thinking you still have control and only finding out that isn't true when you're sliding sideways across the road with a ten ton truck barreling towards you.
Now, you'll want to swap your worn tires around when you rotate, but if your tread depth is below 4/32nds of an inch, you should always have the worse tires in front to provide for better traction in the rain.Last edited by niky; September 4th, 2010 at 11:38 AM.
- May 2008
- 31
September 4th, 2010 12:07 PM #12*niki
di ko na i risk brad, bibili narin ako ng bagong rear tires ngayon.. sigh.. para safe..
September 4th, 2010 01:00 PM #13
September 4th, 2010 07:13 PM #14
Quote Tigkal : If the front tires blow out, you can still steer and be in control. If the rear blows out, it would be out of control.
In which type : Front wheel drive or Rear wheel drive ?
September 4th, 2010 09:16 PM #15
I always put tires with more thread in front for the reason FWD yung car ko and para po pantay yung pagkakalbo nung gulong tapos sabay palit na po both front and rear tires. I just find it more convenient that way + same pa yung thread lahat ng tires. I just drive in a moderate speed when it's rainy to avoid accidents (spin)
I do ask casa to rotate my tires every PMS.
September 4th, 2010 10:35 PM #16
^^^ kaso pag nag rotate ka na ng tires, sa likod na mapupunta ang nasa harap.
December last year, ang new tires ng ZZ ay sa likod ikinabit. ng nagpa rotate ako. nasa harap na. OK lang kasi makakapal pa ang mga threads. more than 60% pa ang old tires. :D
- Jan 2007
- 137
September 4th, 2010 11:09 PM #17http://www.michelinman.com/tire-care...t-questions/#5
Where do I install new tires if I only buy two?
If you’re replacing only two tires, be sure to have the new tires installed on your vehicle’s rear axle. Here’s why:
- New tires will provide better wet grip than your half-worn tires.
- When new tires are installed on the rear, it helps reduce the potential for your vehicle to fishtail or hydroplane in wet conditions.
September 4th, 2010 11:17 PM #18
September 5th, 2010 08:47 PM #19
tires rotation or reposition it only worn out your tire at the same time & costly!
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
