Results 1 to 10 of 34
- Feb 2017
- 30
January 13th, 2018 08:27 PM #1Hi sirs,
Just had my 2012 Vios for 50k PMS and casa recommended to replace front lower arm (left & right). Sa Monday pa mabibigay sakin quotation but right now pa lang gusto ko na makakuha ideas and comparisons:
1. Mga around how much if ako bibili ng replacement part?
2. Any recommended shops na pwede na din mag-install? better if around laguna / alabang area if possible.
Salamat po sa mga sasagot [emoji16]
January 13th, 2018 08:31 PM #2
hanap ka ng bushing replacements and installer.
example lng ito...
imageupload
- Feb 2017
- 30
January 13th, 2018 09:01 PM #3
- Feb 2017
- 30
January 14th, 2018 12:54 AM #5
- Oct 2009
- 2,271
January 14th, 2018 03:22 PM #6kung may bibili per piece lang mas makakamura ka kung tig isa bushing lang sira saka mo ipapa press in & out ang bayad sa mga machine shop ng ganyan.pero may mga talyer naman na may press machine sila.
- Feb 2017
- 30
January 14th, 2018 10:11 PM #7
- 54,285
January 15th, 2018 01:30 AM #8the casa will probably quote the entire assembly, which will cost you an arm and a leg.
but if you have it done outside, and all they do is replace the rubbers, it should be considerably less.
what i do not know, is whether the replacing the rubber only, will give a lasting fix.
January 15th, 2018 08:05 AM #9
Ganyan din sa jazz ko dati. Buong lower arm (including yung bakal) ang gustong palitan ng casa. 13k ata noon. Pag replace lang ng bushing less than 3k sa labas. Kasama na press in/out ng bagong bushing
Madali din masira pag palit bushing lang kaya next ay dinala ko sa cruven para gawan ng bushing (orange ata yun). Sobrang tibay pero di mapatino ang handling.
Nung dinala ko kay mel casaba pinalitan nya ng buong buong assembly pero replacement part lang. less than 2k ata each. Umayos ang handling. Nawala yung kabig.
- May 2012
- 37
January 16th, 2018 06:20 PM #10eto din problem ko with my Isuzu alterra, nagpalit ako ng new front tires, pagdating sa CASA sayang lang alignment daw kasi may alog na, need to replace BALL JOINT LH/RH (2pcs. 9,300) at CONTROL ARM BUSHING (4pcs. 2,800) plus Labor (5,740)
2 days ang repair kasi need pa ipamachineshop, gusto ko rin magcanvass sa mga shops aside sa casa. any opinion?
I have a digital gauge that measures, among other things, engine coolant temp. 90% of the time,...
