Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
    Feb 2017
    Hi sirs,
    Just had my 2012 Vios for 50k PMS and casa recommended to replace front lower arm (left & right). Sa Monday pa mabibigay sakin quotation but right now pa lang gusto ko na makakuha ideas and comparisons:
    1. Mga around how much if ako bibili ng replacement part?
    2. Any recommended shops na pwede na din mag-install? better if around laguna / alabang area if possible.
    Salamat po sa mga sasagot [emoji16]
    hanap ka ng bushing replacements and installer.
    example lng ito...
    imageupload
    Feb 2017
    example lng ito...
    imageupload
    Mga magkano kaya aabutin ng ganyan sir?
    no idea yet. i might do this on our vios also...
    Feb 2017
    Balitaan niyo ko sir if ever you are able to source parts. Worry ko kasi baka sobrang mahal ng i-quote ni casa [emoji28]
    Oct 2009
    kung may bibili per piece lang mas makakamura ka kung tig isa bushing lang sira saka mo ipapa press in & out ang bayad sa mga machine shop ng ganyan.pero may mga talyer naman na may press machine sila.
    Feb 2017
    Quote Originally Posted by jaypee10 View Post
    Noted sir, hirap ng first time tsikot owner and not fully familiar with all technical aspects.
    Will try to update once i get the quote from casa tomorrow.
    Quote Originally Posted by terrajn View Post
    the casa will probably quote the entire assembly, which will cost you an arm and a leg.
    but if you have it done outside, and all they do is replace the rubbers, it should be considerably less.
    what i do not know, is whether the replacing the rubber only, will give a lasting fix.
    Ganyan din sa jazz ko dati. Buong lower arm (including yung bakal) ang gustong palitan ng casa. 13k ata noon. Pag replace lang ng bushing less than 3k sa labas. Kasama na press in/out ng bagong bushing
    Madali din masira pag palit bushing lang kaya next ay dinala ko sa cruven para gawan ng bushing (orange ata yun). Sobrang tibay pero di mapatino ang handling.
    Nung dinala ko kay mel casaba pinalitan nya ng buong buong assembly pero replacement part lang. less than 2k ata each. Umayos ang handling. Nawala yung kabig.
    May 2012
    Quote Originally Posted by robot.sonic View Post
    eto din problem ko with my Isuzu alterra, nagpalit ako ng new front tires, pagdating sa CASA sayang lang alignment daw kasi may alog na, need to replace BALL JOINT LH/RH (2pcs. 9,300) at CONTROL ARM BUSHING (4pcs. 2,800) plus Labor (5,740)
    2 days ang repair kasi need pa ipamachineshop, gusto ko rin magcanvass sa mga shops aside sa casa. any opinion?
Front Lower Arm Replacement
