Results 1 to 10 of 10
    Jul 2003
    car is civic esi 93
    front shock absorbers are busted. rear shock absorbers, i am not sure.
    the rear part looks lower than the front. when the car has 2 rear passengers, the muffler (or something underneath the car) easily hits road humps. the shocks bottom out with 4 passengers plus loaded trunk compartment.
    I'll probably change the shocks (it's been 4 years).
    Is it time to change the rear coils springs also?
    better, kung mahina na o malambot na yung rear coils mo, yun ang nagiging cause ng unbalanced/uneven look.
    Aug 2004
    I'd replace everything at the same time.
    Jan 2009
    ^ That, and it should be done by a reputable shop. Casa is best especially when installing genuine OEM parts.
    Aug 2004
    Actually, there are good outside shops. Casas aren't really much different from outside shops, and there's no reason to pay extra unless your car is still under warranty or you need your ECU scanned for fault codes.
    Jul 2003
    Where can I buy a set of rear coil springs?
    A local shop here in Laguna quoted Php1,900 per piece of KYB. Based on my recent price check on the net, it is not a bad price.
    However, I am not sure if I can find coil springs here.
Is it time for a new rear coil springs?
