Results 1 to 5 of 5
    Sep 2008
    Mga sirs, gusto ko magpa-lower ng kotse. Magkano pinaka murang set-up na ok naman ang performance? And also pls recommend shops na ok mag set up, fairview area po ako. Thanks!!!
    Aug 2006
    it really depends how you like to be lowered, like how many finger gaps you like.
    for starter..try purchasing lowering springs for your ride then try to see if the ride height suits you, if not try adding lifter until your satisfied with the height..
    HTH
    Quote Originally Posted by richiegonzo View Post
    How low do you want to go? How stiff a ride can you accept for your car? What purpose do you have in lowering? Track performance or Street looks?
    Sep 2008
    Quote Originally Posted by earthlyken View Post
    HTH
    around 1.75" na gap between fender and tire sa harap and 2" gap sa likod. tanabe springs cost around 11k daw sa autocircuit. ok na ba yun?
    pinakamurang lowering spring is R1. I think brand new set is around 6k.
    i used to use this, sobrang stiff and tagtag, pero ang lufet sa cornering. hehehehe.
    you have to pair this with gas shocks.
    you can get this at some of the Banawe shops.
Lowering
