Results 11 to 12 of 12
April 19th, 2004 10:02 AM #11Originally posted by carloi
It might also just be tire failure
I'll wait a few more weeks, and if no other tires become flat in that time, then I may consider tire failure as a possibility. I initially considered tire failure as the culprit, since I am still using the OEM Korean Kumho tires on my ride. In the meantime I had inner tubes installed in the flat tires --sayang kasi kung magpapalit na ako ng bagong gulong, eh kung may prankster talaga madadale lang ako ulit
maglagay ka na rin ng camera pointing at your vehicle, parang si Ungas
Is there a separate thread on this? Care to share your tips on how you implemented your surveillance camera set-up?
April 19th, 2004 11:06 AM #12
Kuwento ko lang....
Yung Manager ko dati pinagtripan sa parking. What the tripper did was put a small pebble in the valve cap!
Isnt that ingenious? Kahit gano kapuno ang hangin mo, as long as you screw the cap back in, the air will come out.
Monk-owned R53
