Results 1 to 17 of 17
    Feb 2007
    Hi hope this is the right forum for this.
    I had a flat over the weekend and I think that I ran into a nail.
    I am planning to have the tire vulcanized and a friend of mine told me to look for a shop that "inserts" something instead of yung "niluluto" kasi daw baka lumobo.
    Ayaw ko sana bumili ng bagong tires kasi relatively new pa yung tires and I try to follow the 2,4 rule when changing tires kaya parang impractical bumili ng new tire just for it.
    Inputs naman mga peeps sa decision to have my tire vulcanized. Ano yung sinasabing wag lutuin and stuff. Also is there a recomended shop na pwedeng dalhin after work. Yaw ko na sana paabutin ng sat e.
    Lamatz
    IMHO bili ka na lang ng interior. Mura lang naman di aabot ng isang daan.
    Quote Originally Posted by Karag2 View Post
    Lamatz
    tama yung friend mo. hwag yung niluluto. it affects the integrity of the rubber, making it brittle.
    while the better action is using inserts, it can also affect the integrity of the tire in the long run.
    tama yung suggestion ni maz, bili ka na lang ng interior.
    pwede ba yun interior kung tubeless? how about yun cold patch..pwede na siguro yun
    pwde sir shadow. had an interior placed on my gajah tunggal spare tire kasi di na raw kakayanin ng cold patch, too many holes na raw.
    When you take it to be vulcanized make sure they use a patch on the inside of the tire and a plug for the hole. The patch should use a chemical compound that will bond it to the tire without heating. After all is done then the tire should be good as before the flat. Using an interior does not work with tubeless tires unless you drill a hole in the middle your rims for the valve stem since most modern cars have rims with stem holes on the side.
    double post
    cold patch ako palagi. wala pa naman akong naging problema dun
    Feb 2007
    Thanks mga peeps...
    Hanap nalang ako ng cold patch/inserts ...
    Mar 2007
    It would be best to have it vulcanized in a reputable shop like Tire King or maybe a Shell Service Station rather than vulcanizing shops sa tabi-tabi so that you'll have less worries. Cold patch for me too.
    Sep 2006
    tube for tubeless tire? nope! it will create more heat specially when you go for a long drive! tubeless tires are not designed to be inserted with tube.
    Sep 2004
    Actually, pupuwede ang interior for tubeless tires. I've had it done several times before pag may tama na yung goma ko tapos walang budget to buy a new one. Advisable ang interior kung marami nang butas ang gulong, kesa maraming cold patch. Yun nga lang, pag napako, less than 30 seconds, flat agad, unlike pag tubeless, puwede ka pang makauwi ng bahay (provided na hindi naman kalayuan).
    AFAIK, yung mga interior lang naman yung pinaplantsa/niluluto. Yung mga tubeless, cold patch na ngayon or yung may ini-insert na parang gel to plug the hole. For bigger holes, meron na yung patch na may ply, para mas matibay (naks, it rhymes!)
    kapag marami na ngang butas ang gulong, sa experience ko mas ok na maglagay ng interior. mas matagal pa magbawas ng hangin ang gulong. sa reserbang gulong dapat talagang may interior para parating may hangin ang reserba. kapag wala kasing interior ang reserba nawawalan ng hangin ang gulong.
    The tire repair kit i've used for vulcanizing is the insert method (used this for several years already) and it works quite fine. No uneven tire pressure drop or deterioration of the insert. When i saw that my tire had a nail when i was in the Fort, that's what Autotechnika used as well (the line in Bridgestone was long and they could not even accomodate a flat tire inbetween).
    Jan 2008
    Lamatz
    Sir tubeless nman ata yung tire mo eh...patusok mo nlang yan....sa shell or sa servitek mo dalin..100 lang per butas sa tire,mas matibay pa yun.
    Feb 2007
    Thanks ... just an update ...
    last sat pinalagyan ko nalang ng cold inserts yung tire...
    natawa nalang ako dahil sa ang liit lang ng pako pero chumempo pa sya dun sa portion na manipis... ayun sumingaw...
    nagpagawa ko sa goodyear servitek along dimasalang...
    60 petot per insert ang singil... it was a quick job kaya me konting kwento pa dun sa mga gumawa...
    btw sinabihan din ako na marupok na raw yung gulong... tiningnan ko and true enough naman meron nang mga cracks... 3k rin kasi ang gulong kaya di ko na muna pinalitan...
    any ideas dun sa "marupok"... kelangan na bang palitan... kasi kung sa kapal lang... tinapat ako ng gumawa dun na tatagal sya... dont know much about dun sa "rupok" kaya napapapaisip tuloy ako kung kelangan palitan (gastos nanaman)
    thanks...
    ilang taon na bang gulong mo?
flat tire
