guys, is to possible to install 30X9.5X15 tires without altering the
stock suspension/steering/gearing setup of a 2001 Frontier 4X2?
thanks!
thanks!
What is the exact outside diameter of that tire? It would probably fit....but you might need to cut/remove some of the corner of the plastic mud guard. The 2001 4x2 comes on a 14" rim kasi and the overall outside diameter is 27".... so you're adding 3" assuming 30" nga talaga ng diameter....may be you should crank the torsion bar by about an inch just to make sure....I cranked mine by about 1/2 to 1"....but I haven't replaced my tires yet....I'm planning to put in a hand me down na michellin LT na 31" but I haven't got the dough to buy the rims yet.
You will definitelty need to lift the front with those tires, torsion bar cranking will do. But if it isn't done right - it'll ride stiff.
yes, how can we do it right? san ok pagawa 'to? tsaka parang nabasa ko somewhere na problema daw ang camber/allignment pag nag-crank ka ng torsion bar? is this true.
wildthing,
i think 15" yung stock rim ng 2001 4x2... 215R15 kasi yung tires na nakakabit.
wildthing,
di ba naging harsh yung ride pagkatapos ng cranking ng torsion bar mo?
san mo pinagawa? salamat.
kelso::: torsion bar cranks can be done at any decent alignment or suspension shop. The problem is, maiiba yung alignment settings ng kotse mo. Of course to wear out your tires better, have a full alignment done.
I had mine done at Servitek. Free of charge po yung torsion bar crank(im a regular), with the full alignment, which costs around Php1,200.00. My Alignment guy just asks me if i want to lift or lower the front before he aligns.
how about sa patrol? if i will change my tires to 275/70R16 from 265/70R16 (stock rims pa rin), will i have to alter anything?
Signature
it may fit IMO kilala ko has 225/70/16 sa frontier ya na 4x2. patrol mags.
boybi,
Kaya ng Patrol hanggang 32" sigurado. Minsan sumasaksak pa ang 33" without modifications, eh.
ser boybi pasok na pasok yan for sure! (AY BASTOS!)
kelso hatch:: rough estimate---> 141 inches tall
pajerokid, 141in = 11.75 ft.!! ang laking wheels nun a :mrgreen:
Kelso Hatch, mga 28.4 inches po.
Signature
Hindi naman...but I was opting for a taller stance...but when we did it...pangit na ang response ng shocks...we have to decrease it by roughly 1/2 an inch....totally we ended up with raising it by at least 1/2 to 1 inch taller than it use to be....di ba naging harsh yung ride pagkatapos ng cranking ng torsion bar mo?
san mo pinagawa?
Ipinagawa ko yung torsion crank sa casa ng Nissan in Sn Fernando Pamp. in one of my scheduled servicing.
My stock wheels were 195R14 its a 4x2 Standard....I believe your 4x2 is an elite version kaya 15" ang rims. You could roughly fit a bigger tires if you would still have a 2" difference from the edge of the fenders/fender flares to the surface of the new tire....my visual estimate is that I can have around 30" tires pa....but I could be wrong...why don't you test fit one muna...
To gain better spacing for your planned bigger wheels...I have researched that the frontier will have to have either a suspension lift or a body lift....A body lift could be as low as P7,000 for the frontier all-in and its a 3" lift. An imported A-arm for the front would cost you about US$350-500 for a pair (Calmini, Fabtech, or AC 4x4 brands) - I'm not sure if its locally available.
As for the rear, a good taller shackles is a good change (P1,000-4,000) for 4 pieces or 2 pairs. But as for me, I'm seriously considering a modification of leaf-spring-over-differential conversion. The shackles will be the stock. A possible repositioning of the rear shocks is required - cost...I don't know yet...maybe around P3,000 at least.
As I am closely observing the stance of the 4x4 Pathfinder - I noticed that the A-arms were normal ones but it does have a body lift (maybe just around 2" and the rear is a leafspring-over-differential configuration...unlike the standar pick-ups like in the 4x2 frontier...no body lift and the rear is leafspring -under-differential setup.
My 2 cents.
boybi, kelso::: oh my gulay!!!! oo nga ano. sorry po!!!!!! di pa ako nagdi-dinner. gutom po yan hehehe :oops: :oops:
ay paumanhin po sa erroneous computation!!!! :oops::oops::oops:
di pa po ako nagdui-dinner kanina eh hehehe :mrgreen:
PK,
no problem.
Wildthing,
Mas maganda nga siguro yung suggestion mo na mag-fit muna ako ng gulong. Diba masyadong mataas yon pag nilagay sa ilalim ng leaf spring ang differential. Ganito yata ang set-up ng frontier 4X4 eh, sa body lift paraho lang sila ng elite... ewan ko lang sa front kung may mods ang 4x4.
ot: Tiga-pamp ka rin pala. Baka sa 'yo yung nakita ko na white 2.7S na naka mesh type grille. Simple pero maganda tignan.
Just a factor to consider when putting in larger tires.
My ride is a Mazda B25 4x4, stock tires if I remember right is 195/65R16 (makitid siya na mataas). Bought second hand Pajero mags and Michelin LTX 31x10.5R15 tires. Cranked up the torsion bars to fit.
Ok naman, kaso one time me mabigat ako cargo sa likod plus puno rin ng passengers sa loob. Pag todo kabig manibela, I heard a scraping sound... ayun sayad pala gulong sa harap sa bandang dulo ng fender :cry:
Wala na ko budget for a body lift kaya ngayon di siya pwede kargahan ng mabigat...
kaya pag me hihiram at mag load sa likod me dahilan na ko para wag magpahiram hehe..
:mrgreen: :mrgreen:
Extreme torsion bar cranking can cause camber disalignment - so it has got to be done moderately.
When I say done properly, your mechanic must adjust the anti-sway bar and bump stops to conform with the new stance of the A arm.
