Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Oct 2004
    Anyone nakaexperience na sa inyo when turning the wheels - i mean full turning the car would make tak-tak-tak-tak sound.
    The scenario:
    From full stop, full-turned the wheel to the left and begin accelerate then I hear the annoying sound above until mawawala lang if i straighten the wheels and go straight ahead. The faster i turn the noisier.
    Ano kaya problema?
    Dec 2003
    my guess is velocity joint..
    CV joints iyan (aka velocity joints). Usually papalitan na iyan, hindi na pwede daanin sa repack.
    It's not a very expensive procedure. Aside from the CV, you will also need new boots and axle grease.
    Oct 2004
    I'll check the CV joints then.
    Oct 2004
    Well, I'll be damned.. searched/found a similar car with a similar problem..
    http://www.startribune.com/stories/432/5194824.html
    thanks to otep and BB for the replies and the "keyword" :-D
    CV joint... ah late na pala
    Oct 2004
    Here's just to give you guys an idea.
    2 brake disks reface and installation - 280 each (560) plus 300 labor - P 860.00
    2 tie rods repair - 150 each - P 300.00
    2 rack end repair - 150 each - P 300.00
    2 stabilizer link repair - 150 each - P 300.00
    4 upper/lower balljoint repair - 150 each - P 300.00
    4 shock abs. refill (front and rear) - 400 each - P 1600.00
    2 caliper overhaul (replaced 1 piston) - 150 each - P 300.00
    4 cv joints and axle overhaul & repack - 120 each - P 480.00
    4 f.w. bearings repack - P 400.00
    2 break shoes bonding and adjustment (1 each side) 180 plus 200 labor - P 380.00
    1 caliper piston - P 450.00 (not brand new)
    1 break fluid - P 60.00
    1 axle grease - P 300.00
    Total Expenses : P 5330.00
    To think na pumunta lang ako para paayos cv joint ko at mag-pa-reface. Heheh.. Anyway, pinapakiramdaman ko pa kung ok gawa nila since Saturday and since they gave me 3 mo. gaurantee. Sabi kc nung mayari nung shop.. try na muna nila i-repair kc sayang naman mga original parts tska mas mura na alternative kaysa sa mga replacements. If problem persists dalhin na lang sa kanila ulit to replace na un joint free labor.
    What do you guys think???
    OT: Nakakainis talaga ninakawan na naman ako ng side mirror this morning!!! Grrrrr...
    Quote Originally Posted by KALAMPAG View Post
    -sir saan shop to?
    I think dapat pinapalitan mo na agad yung CV joint instead of having him do all those services (some of which might have been needed in the first place).
    But that's just me.
    Oct 2004
    Hmmm.. you think so sir Otep? D rin kc ako ka-confident dun sa solusyon or should i say remedyo. Papakiramdaman ko na lang. Worst case pede mangyari would be masira ng tuluyan un joint and d na makaandar un sasakyan.
    Thanks for your opinion.
    Para sakin masokay kung palit na lang agad kaysa sa repair or repack.
    Mahirap na kasi pag yan ang bumigay eh..lalo na sa suspension pa yan.
    Feb 2005
    hi po pwede rin po ba ako makisali dito..?
    kasi po un car ko lancer (un luma lng po.) madami na po sya prob.(secondhand ko po nabili.last yr jun. 125t lng po sya) kaya lng po wala po kasi ako kilala talaga dito na may alam sa car (lola lng po kasi kasama ko, wala po dito fam. ko..)
    kaya tuloy di ko po gaano naaasikasuhan.. and when i drive my car palagi po agad nalang umiinit ang makina and one day pina check up ko tapos un sinagot po nila need ko daw po pa over?watever..?.. and sabi po nila need ko den palitan un ragietor?(tama po ba? un nasa harap na parang may fan..)
    basta po sabi po nila luma na kasi un model(model 89 po ata sya..) kaya baka bibigay na? and sabi po nila 15t lng daw po lahat lahat.. (ganun lang po ba un?)
    and un pinaka prob. daw po nya kasi kumakain sya ng oil, so palagi nalang may usok..
    (pero po as off now di pa rin nya ako hinintuhan sa daan... pero minsan kinakabahan po ako.. hahahaha..)
    so,, gusto ko po sana mg palit ng car! (eto po talaga un gsto ko i ask..)
    un choice ko po kasi un HONDA Hantchbox? or un po mitsubishi GSR (di ko po alam un model ng yr pero po un 2doors na parang sinkit un windows nya..)
    maga mg kano po ba mga ganun models? un secondhand po.. 1yr pa lang po kasi ako ng ddrive..
    sana po give me po some advice..
    tnx po..
    May 2004
    Quote Originally Posted by tagalog grl
    tnx po..
    wow! sobra ang galang mo. so, gusto mo na lang mag-palit ng car
    instead of overhauling your engine & changing radiator ganun ba.
    wag kang mag-alala. i'm sure maraming mag bibigay ng advice sayo dito. sorry, at wala akong mabigay na advice sayo...na intrigue lang kse ako sa
    sobrang galang mong mag-post. first post mo pala ito, welcome
    to tsikot.
    Feb 2005
    hi po. :hi: tnx po ah. :thanx: and tnx den po sa welcome nyo.. kaya lng po un prob. ko hangan ngyon di ko pa rin po magawa mg post ng bago.. hahaahha, kaya po eto nakikisali nalang po ako sa naka post..(pasensya na po..)
    nwy po any help will be appreciated very much po tlga..
    tNx pO~ :heart:
    Hi Ganyan din problem ng beamer ko na luma, nasira yung engine ko which cause of always overheating. Nagsimula yan nung hindi ko napansin na sira pala yung radiator fan ko kaya ako na overheat. Then nadamay yung engine ko kse nasira yung Gasket master ng engine, ayun, bumili ako ng overhauling kit tapos pina machine shop ko pa yung engine kse kailangan na ireface kse hindi na lapat yung engine. umabot ako ng 25k amp!
    Feb 2004
    OT magalang talga yan si tagalog grl :D
    Dec 2003
    kuha ka nalang po ng lancer GSR or GLXI, price nyan mga 260-300T, mdyo mahal compared sa lancer mo pero mas walang sakit sa ulo lalo na kng marami nang napalitan sa mabili mo. honda civic hatchback ok rin, price is 180T to 250T. honda civic ESI is another choice, 240T more or less. benta nyo nalang po lancer nyo, yan lang po senorita!
    Feb 2005
    hi po tnx po (^u^) pero po sa tigin nyo po mga mg kano ko po ma ibebenta un lancer?
    kng madami po sira baka 50t po ba? may ng sabi po kasi sa skin un clasmate ko sabi po nya 70t mahal na daw po un. (kasi po nagas gas ko.. and may nabakbak.. and nahulog ko po un black sa side nya..di ko kasi napansin na wala na pla eh.. hahahaha,.>_<)
    pero po un budget ko base po sa mag kano mabebenta un lancer and konti.. (mga po 100+..)
    so kng ganun hangan sa hantcbox nalang po ata ako?
    hi tagalog grl......... maibebenta mo cguro yung ride mo nga 50K na lang (depende talaga sa overall condition nung car). kung 100 + ang budget mo pwede rin sayo yung 1991 or 1992 toyota corolla XL. around 130K ang price nun saka matipid pa sa gas. di rin sya mahirap i-maintain at ang parts marami kahit surplus parts kalat lang sa mga shops.
    Oct 2004
    yun frontier ko may tumutunog din galing sa ilalim pag fullturn sa u-turn slots. Ano kaya iyon? pag maintenance check-up nawawala naman. Tapos babalik after a few months.
    Iniisip ko baka kulang lang sa grasa
What's with the takatak?
