Results 1 to 12 of 12
    Jan 2008
    Greetings!
    Damaged na po steering wheel ko, I'm planning po to have it covered with leather sa Seatmate. Can they really do it without any negative effect on the airbag? Sbi kasi kailangan talaga muna matanggal yung steering wheel. TIA
    Jan 2008
    paki lipat na lang po sa Workshop. Thanks!
    Quote Originally Posted by enzo18 View Post
    moved
    Sep 2005
    Greetings!
    The airbag system must be deactivated first before doing any work on an airbag-equpped steering wheel. This is to avoid the accidental deployment of the airbag and/or the registration of an SRS fault in the car's ECU or computer.
    If they know how to do it, there should be no problem.
    unpluged ang battery both positive and negtive para sure safe ang airbag ...
    Sep 2004
    Yup, disconnect the battery for at least 20 minutes (to dissipate residual electricity).
    Also, kung may separate fuse for the airbag, ask them to remove it too
    Jan 2008
    thanks fellows! eto na yung result!
    ganda ng pagkakagawa .... magkano inabot nyan sir?
OK lang ba pa cover ng leather ang steering wheel na may airbag?
