mga sir patulong nmn kc pagfull steer ako sa right my natulog na prang nasabit tapos my natunog.. i experience this since ngpapalit ako ng water pump.. ano kya sa tingin nyo mga sir?
Is your car a rear wheel drive or front wheel drive?
If its happens only when you turn right is sounds like the wheel bearing on the left(not right bearing). Check your wheel bearing on the left side. If it is a front wheel drive could be the CV joint, see if the axle boot kung torn up na.
