Results 1 to 12 of 12
    Jan 1970
    Guys will you help me out again on this... Ano kaya ang problema nitong ride ko...tumutonog minsan pag nag apply ako ng brake na parang ganito... enggggggggggggggggg.... Pero malakas pa naman ang kapit ng brake....
    Many thanks at God bless you all.... :D
    for the front, possibilities are warped rotors, worn-out brake pads
    for the rear, worn-out break shoe, dirty drum brakes.
    Jan 1970
    Artpogi, ano kayang mabuting gawin dito????
    Is this a sign na dapat ng palitan ang break pads???
    Thanks
    Quote Originally Posted by Jolam143
    Thanks
    have it checked especially the front, kasi kung warped na rotors mo, useless ang palit mo ng brake pads, madali mauubos yan.
    Kapain mo yung rotors mo, kung meron kang makapa na guhit na magaspang at malalim na then its time to have it refaced. Of course, once nagpa reface ka ng rotor, palit ka ng bagong brake pad.
    Jan 1970
    hi guys, pasingit na ren. i have the same prob on my ae101. maingay yung harap, so i changed brake pads (the one that sells for 400 pisotas lang--peke), nawala ingay, after a few days bumalik ulet. so the mechanic suggested a reface dahil meorn na nga umbok yung rotors, had it refaced, nawala noise, but after a few days maingay na naman. suggest naman ng mechanic that i change the brake pads to my old one (originals) dahil medyo makapal pa daw. it might be that the fake brake pads are to hard. im pretty confused on what to do. malakas pa naman kapit ng brakes, but the noise is freakin annoying. i appreciate ur suggestions guys. thanks
    Worn out brake pads. Have it replaced. Goodluck.
    Jan 1970
    pero bro, its using new brake pads, yun nga lang peke. do u think its wise that i replace it wid my old original one? makapal pa kasi e.
    use OEM pads. the peke ones squicks :wink:
    Jan 1970
    Pasensya na bro bago pa kasi ako dito eh....ano ba ibig sabihin ng OEM, HU at ano ba tung rotors???? :D
    Feb 2003
    kapag fake yung brake pads, malakas pa din kapit, pero iingay pa din after few days..kapag orig ,sobra mahal, but ndi iingay brakes mo kahit ano gawain...
    dun sa tumutunog na brake, very possible na galing sya sa likod, drum brakes, malamang nabasa then tinaas yung handbrakes, and left it overnight, the next day , tutunog talaga yan...mas audible ang tunog pag a/t ang car...
    Dec 2002
    sir jolam143........
    OEM stands for Standard Equipment Manufacturer
    HU yata is Headunit.
    Jan 1970
    Bat naging Standard Equipment Manufacturer eh OEM di ba dapat SEM, di kaya Original Equipment Manufacturer, Sir Jun????? 8O. .. So this means na kung ang ride mo ay Mitsubishi dapat original na Mitsubishi spare parts ang bibilhin. kung Toyota orig din na Toyota....
    Di ba meron din brake pads na made in Japan pero hindi Toyota or Mitsubishi ang brand.... Maganda din kaya ang performance ng mga brake pads na ito????
Tumutunog ang brake
