may tanong ako
may epekto ba sa odometer ang non stock tires?
i read in another forum that using, say for example, oversized non stock tires affects your speedometer reading. lets say your stock tires are 265s, if you change to 275s (same rims), there is a 1% difference in the speedometer reading; or if you change to 285s, there is a 7% difference.
to illustrate, if on the stock 265s your speedometer reading is 60kph, then on the 275s, the speedometer will only read about 59kph (or thereabouts) or much slower. tama ba? o baliktad? the main thing is that there is a difference
if this is the case, is the odometer reading also affected?
by the way, nag search na rin ako and i was not able to find a thread specifically discussing this. kung medyo kulang ang search ko, paki post nalang ng link dito
salamat sa lahat![]()
:question:
