Results 1 to 2 of 2
    Apr 2009
    I plan to replace both of my cv joints for corolla 1997 gli,what other parts should i consider replacing near the cv joint area para 1 time labor na lang
    Feb 2020
    Quote Originally Posted by bail View Post
    If you are a DIY, check if the outer/hubside and inner/transmission side joint bearings of both axles have rotation problems.
    If none and there is no grease leakage on all boots, suggest that simply have all joints cleaned and repacked with specified CV grease. You might as well have all boots replaced too thus need 2x pairs of CV boot clamps for each axle too.
    Hope this feedback helps.
Cv joint replacement ques
