Results 1 to 5 of 5
    Aug 2005
    Hi all, patulong po sa problem
    yung '86 boxtype gsr ko nagwi-wiggle when running at 60kph and above, pati yung steering wheel nagwi-wiggle din, malakas.
    pag straight yung daan, umaabot ng 70kph without wiggle, pero once me un-even road or kahit konting lubak lang dun nagwi-wiggle. minsan kahit 40kph lang takbo ko pag me un-even road nagwi-wiggle pa rin.
    tires are ok naman, though surplus lang sila, more than a year na rin pero makapal pa.
    30psi harap at likod na gulong.
    thanks
    Front suspension parts mo bro mukhang me tama na. It could be a combination of your tie rods, rack ends, sway bar, balljoints. Have it checked immediately as this could be a dangerous proposition should you continue to drive your car without having your car checked and have the necessary components replaced.
    Jul 2003
    all wheels should be properly balanced by your tire shop.
    lug nuts must be properly torqued.
    i have a hunch na baka tire ang problema. baka oblong na, since surplus sya... check mo muna condition nung tires.
    Aug 2005
    i'll have it check today, then update ko later what's the mechanic's findings
Wiggle at 60kph
