Results 1 to 10 of 11
May 18th, 2007 09:22 PM #1
mga tol tama ba formula ko to compute for the overall wheel diameter?
Tire width * Aspect ratio = Tire sidewall height
Tire sidewall height * 2 + Wheel diameter = Overall wheel diameter
i was wondering kase ano sukat ng mags at goma ang equal sa stock ng altis which is 195/60 R15.
May 18th, 2007 09:25 PM #2
Just google for a 'tire calculator' to solve your worries. :D
The rough computation is section width X aspect ratio (in percent). So 195 X .60.
The answer you will get is sidewall height.
Sidewall height X 2 + rim diameter will give you overall diameter.
But nothing beats actually taking a tape measure and measuring the actual tire installed on the actual rim.
May 18th, 2007 09:40 PM #3
thanks, i found this site http://www.1010tires.com/TireSizeCalculator.asp.
tires measuring 245/45 R16 would be slightly bigger sa stock ng altis. may ganto ba sukat dito sa pinas?
May 19th, 2007 07:02 PM #4
Very hard to find tires in that size... and they're usually sports tires, which cost quite a bit.
I'm also pretty sure 245's will rub on the fender liners when you're turning, unless you have the proper rim offset. You'll also probably need to make sure you have a 7" or 7.5" wide rim for that. 245s won't fit well on your regular 6" wide rim.
May 21st, 2007 08:03 AM #5
May 21st, 2007 08:49 AM #7
May 21st, 2007 09:06 AM #8
Kung may Java Runtime yang PC mo, i-try mo ito Tire Size Calculator. May kasamang pictures para mas ma-visualize mo.
May 22nd, 2007 11:45 AM #9
They'll void your mags warranty. The suspension warranty is supposedly voided, but that's a wear item, anyway, and the warranty on suspension components is often very short, unless there's an internal memo regarding premature failures of certain parts.
Bigger mags will definitely wear out bearings and bushings faster, but not at an appreciable rate, and not enough to be worrisome. Mas malaki pa ang effect ng potholes at bumps kaysa sa mags.
May 22nd, 2007 12:03 PM #10
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
