Results 1 to 7 of 7
September 22nd, 2016 01:00 PM #1
Need help you guys. Sa tingin nyo ba based on the pics below, time to replace the bushings na?
May hinahanap kasi ako parang clapping sound kapag inaalog ko yung car sa rear. Wala pa kasi ako time dumaan sa Casa and I'm planning to have them check this at my 40k pms. Hindi rin naman wobbly yung ride kaso naiinis lang ako na may naririnig kapag napapadaan sa hump
Unit: 2015 Ertiga GL
Thanks
Lower Left Side
Upper Left Side
Upper Right Side
Lower Left Side
Sent from my Asus ZenFone 2 using Tapatalk
September 22nd, 2016 01:03 PM #2
Weird thing though... that clapping sound all started ng medyo napadalas ang pagdaan ko sa baha.
May mga times na nawawala pero this time around hindi na
September 22nd, 2016 01:37 PM #3
visually, mukhang ok pa naman, but it could be different kung actual visual na talaga.
since kamo lumabas yan nung dumadaan ka sa baha, it could be that the rubber is not that elastic than before. namaga na and di na bumabalik sa dati nyang characteristics.
pa check mo na lang din sa 40k PMS mo.
- Oct 2009
- 2,271
September 22nd, 2016 02:07 PM #4hayaan mo na muna .after 2 weeks kapag hindi nawala saka mo na ipa check, mukang ok pa naman yang rubber na nasa picture.
September 23rd, 2016 09:11 AM #5
Thanks for checking. I'm kinda dumbfounded kung yan nga source.
Nagpa carwash lang ako kahapon meron pa rin tunog kaso humina naman.
Malalaman sa 40k pms sana
- Mar 2013
- 220
October 6th, 2016 07:49 PM #6Walang marks sir na nagtatama sila mukhang hindi jan.?ano ride nyo po?
Clapping sound?.... disc pads.... shock bushing.... suspension bushing.... exhaust pipe rubber support ( kung ano man tawag jan hehe)
November 28th, 2016 01:59 PM #7
Found the culprit if the clapping noise during my 40k pms...
One of the clips that locks the brake shoe in place medyo worn out na kaya may konting play.
The mechanic just had to replace the clip to properly hold the brake shoe in place
