Results 1 to 4 of 4
- Jan 2006
- 15
December 22nd, 2009 11:34 PM #1I just purchased a 09 Camry 2.4 last Feb. and around 2 months ago, I noticed a loud clicking sound coming from the brake pedal everytime I run the car for the first minute or 2. It occurs everytime I start the car anytime of the day and travel for a few hundred meters. I brought it to the casa and yet, they told me it was normal, which i think is not true since this sound never occured when I bought the unit. Ang nakakainis pa sa casa, they road tested the car for 20 kms (as seen in the odometer) just to tell me that they could not located the problem and so, it's just normal.
Any thoughts on the possible problem? I remember experiencing a loud "thug" noise in the brake pedal as I was going down an incline just after starting the car. After that incident, the noise would always occur without fail. tia
December 23rd, 2009 10:40 AM #2
have you had the calipers checked for loose nuts and bolts? baka nandun lang.
- Jan 2006
- 15
December 26th, 2009 09:31 PM #3Will ask the casa to do it. thanks for the advice. Hindi kaya sa brake master?
- Oct 2009
- 35
December 28th, 2009 05:54 AM #4What's the mileage on your ride? You know brake pads are designed to have like an irritating noise like a screeching sound or like what you said a click to alert the driver to replace it when its worn already. Baka manipis na ung break pad. Do you do long drives? Or it could be a leak somewhere in your brakelines that will cause noises also coz your losing break fluids if that's the case.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
