View Poll Results: What is your tire pressure? (front tires if front & rear tires aren't the same)
Voters
288. You may not vote on this poll
  • 24 & less psi
    2 0.69%
  • 25-26 psi
    3 1.04%
  • 27-28 psi
    15 5.21%
  • 29-30 psi
    110 38.19%
  • 31-32 psi
    88 30.56%
  • 33-34 psi
    24 8.33%
  • 35-36 psi
    31 10.76%
  • 37-38 psi
    6 2.08%
  • 39-40 psi
    7 2.43%
  • 41 & up psi
    2 0.69%
Page 1 of 8 12345 ... LastLast
Results 1 to 20 of 209
    [SIZE=4]What air pressure do you use in your tires? [/SIZE]
    Just to make it simple, front tires.
    The reason for this poll is this: assuming everything is working fine with your car, tire pressure & wind resistance are the two factors which can affect fuel consumption.
    Tire pressure - the less rolling resistance, the better fuel consuption. So using higher pressures will decrease rolling resistance of your wheels.
    Wind resistance - air drag on your car increases exponentially as speed increases, so keeping a max speed of around 90 kph is said to be optimum for best fuel milage.
    Since we can't change the shape of our cars (much), I'll concentrate on tire pressure.
    32 psi
    at
    30 psi
    30psi
    Jun 2005
    33 psi
    Jun 2005
    40 psi front, 42 psi rear
    Aug 2004
    32 on all four (185/70R13 Bridgestone Turanza ER60)
    Since the gas station is a bit far from the house I always fill up with 32 instead of 30 to compensate for the heat of the tires. Am I doing the right thing?
    Feb 2005
    27 psi front/back 185x70x13 lancer-boxtype
    Aug 2005
    20 in front and 25 at the back.. is this ok? the car is a Lancer '96..
    and the tires are the still the original..
    I was just told that I should keep the pressure at those values..
    Quote Originally Posted by Smoke XIII
    what is your tire size?
    your tire pressure seems to be pretty low ... 20psi front & 25psi rear
    Currently I am trying out higher than recommended pressures to find better fuel milage at cost of some riding comfort. Anyway, I am usually the only one riding. Right now my pressure is 35psi front & rear.
    Jun 2004
    33 front, 32 rear
    I just follow the recommended values printed on the sticker by the driver side door.
    34/32 ang akin, yun nakalagay sa oto eh.
    yung sa benz dati 33/36 ata
    30 psi on all four wheels... as per the specs for the Rav4 (regardless of load).
    May 2007
    Quote Originally Posted by mazdamazda View Post
    True!!! Used specs that recommend by manufacturer on your OEM. If you change your tire to a diff. brand, go with the tire manufacturer recommended inflation usually located on the sidewall of the tire.
    Car - 30psi - Michelin ???
    Van1 - 32psi - Goodyear Wrangler
    Van2 - 35psi - Michelin Vanpix
    4101:victory:
    Jul 2006
    I just had to fill up with air on all 4 tires. Temperatures here are getting cooler. Just a reminder to you all to check tire pressures when experiencing big temperature changes.
    Generally when the temperature drops, so do tire pressures.
    http://www.tirerack.com/tires/tirete....jsp?techid=73
    Aug 2005
    I use 35 psi for all 4 wheels. After 2 weeks, mga 30 to 32 na lang sila.
    34 psi on all fours..
    better fuel economy.. from 5-6 km/L increased to 7.5 km/L
    Jul 2004
    Quote Originally Posted by kiper
    bro -- so overinflation works pala in fuel economy
    anong recommended mong tire pressure ko for 275 70 R16 tires on a 01 patrol GU? right now naka 30 psi lang ako (cold)
    thanks
    since I increased from 30 psi to 35 psi... I think I am getting better milage.
Your Tire Pressure
