Mga guru, ask ko lng po my car is honda city 1.5 vtec mt, nagpapalit ako ng front hub bearing kanina, while driving ive notice na naka on pa rin ang indicator ng abs at handbrake, malaking problema po ba ito? Kelangan ko p ba ipareset yung computer code ba yun, please need ur advise, thanks
Replacement koyo brand po napakabit, i dnt know kung sa pyesa ang problema. Nagtry na din ako magreset ng ecu, i removed battery terminal but still abs lights stay on, mukhang hindi ngreset. Im planning to remove fuse pero di ko alam which fuse, please help eto po ang photo ng fuses ko
Koyo is a good brand (and is actually an OEM manufacturer). Better check if the hub you got is for an ABS-equipped unit.
I used Koyo for the Vios of my in-laws. These were cheaper than the OEM Toyota hubs and were made in Japan unlike the Thailand origin of the OEM ones. I had to specify too that the unit was ABS-equipped as the ones for non-ABS vehicles are different.
