Results 1 to 4 of 4
    i observed that my tires on my pajero have uneven wears both front and back. A few months ago i have it aligned thinking that it will eliminate the problem....sad to say but i'm not satisfied with the improvements.
    do i need to replace some of the suspensions like lower ball joint,idler/pitman arm and innner/outter tie rods...
    need your advice on this....
    wears on my tires particulary in the front are on the sides and the rear tires have uneven wears........(wears looks like teeth of the saw)
    What were you doing before you experienced your tire wear?
    How old is your vehicle?
    Any modifications done?
    Let us know so we can help diagnose your problem better.
    Aug 2004
    Quote Originally Posted by kross View Post
    When they aligned the wheels did they checked the camber? I suggest also to rotate your wheels after the camber.
    Quote Originally Posted by HardCharger View Post
    By the time i noticed that the tires have uneven wears i have it aligned directly..they didnt check the camber....just the wheel alignment. This happens on the 5th or 6th months after i purchase the car. Right now still not satisfied with the results....maybe there are few improvements but the problem is still there.
    Vehicle is pajero exceed (surplus unit)....purchased this unit 'bout a year ago i think or 1yr plus....
    Considering this is a surplus i think this is already 10 plus....
    haven't done any modifications on my suspensions...
    Before,my mechanic just change the left pitman arm 'coz car was shaking everytime i reached 40 or 50km/hr. Other than that no modifications has been done......
    thanks in advance.....
need advise on my tires...
