front brembos (rotors, calipers, lines, etc) will set you back $2-3000 as i said earlier. pero wala ka mahahanap dito na brembo for a civic. if you want rotors lang you can look for them locally kila mato kasi i think he used to distribute the stock sized x-drilled rotors.
there are other possibilities such as ebc rotors which will go for around 20T +-, for the brand new dimpled and slotted front rotors. meron ata nyan locally. front lang yun. figure another 10-15T for the rear rotors.
i also think that autoplus has type r big brakes na brand new, front and rear. these are big na and are strong when coupled to the correct pads. they also have Spoon 4-pot calipers as well as AP's which should fit your civic. these should be in the 60-80T price range pero i'm not sure.
before you upgrade to serious stopping, be sure muna na di na kaya ng stock brakes mo. in my experience, sir brakes improve a lot when you put steel braided line, dot 4 fluid and decent pads (ebc, winmax, etc) so most don't upgrade na.
