Results 1 to 3 of 3
    Dec 2009
    Mga sir, may tanong ako kanina pa exit ako ng tollgate na naramdaman ko na mejo kumakadyot kadyot yung car ko parang hingal yung makina at sound ng muffler tapos tumigas yung apakan ng preno, kailangan isagad mo apak para mag break tapos mahina ang kapit ng break, buti nasa tollgate kaya stop and go.. mazda 3 pala car ko.. sir ano kaya problem? ok naman ang break fluid at ATF, x2 na nangyari sakin toh eh buti mabagal nung naaabutan ako.. natatakot ako baka maabutan ako along highway mawalan ul;it ako ng preno.. sana matulungan nyo ko...
    Feb 2009
    Quote Originally Posted by paolo37 View Post
    your car is trying to take a [B]break[B], it might be tired. from your description, it seems like the engine is misfiring and the [B]brake[B] booster is not able to boost your pedal effort
    Chief Paolo37,
    Chief Jick was correct on the idea that the cause of the brake failure was your stalling engine. Might want to check your fuel system such as the Fuel pump & Fuel filter. Better have your car checked first before using it specially along expressways or you might end up being towed & suffer the towing business .
Break Problem need help please
