Results 1 to 18 of 18
    Dec 2002
    tanung lang po: :D :o
    bkit kaya pag nag b break ako ay nararamdamang kong parang nanginginig ang steering......especially kung mabilis ang takbo dennag break, ang hirap kontrolin ng steering....bkit kaya?
    kaka align, wheel balance, and camber pa lang ns sasakyan ko.
    better have it checked sa reputable shop or CASA....... buhay mo ang nakasalalay diyan......
    Check mo break balance dapat pantay lahat ng distribution ng brakes para hindi kumakabig pag nag preno. Try to check din kung yung disc brakes sa harap e hindi pa deformed. I mean yung disc surface dapat ay pantay. Kunguka-uka na yun, baka kailangan nang ipa reface. Subukan mo din ipa bleed ulit yung fluid, bka may kabag o hangin yung break lines.
    Hope this give idea. :mrgreen:
    Quote Originally Posted by kupaloids
    patingin mo na, mas madaling magpagawa ng sasakyan kesa mga buto buto or magpagamot. 8) 8) 8)
    classic case for warped discs.....have them checked and resurfaced
    Quote Originally Posted by jun
    is your car a mtisu galant?
    tama si enigmazutapia . Pa-check mo yung rotor mo. Basta pag dating sa rotors naka isa o dalawang cut na yan kailangan ng palitan yan ng bago..
    RIDE ON...8)8)8)
    Dec 2002
    Yung sa Besta ko may problema din sa brakes. Kumakabig sa kanan pag-nagbrake ako. Minsan naman wala, diretso ang pag-brake. Tapos whenever I do a u-turn may tumutunog na TUG sa ilalim. Ano kaya problema ?
    Ipa-service ninyo yung brakes ninyo baka marumi lang. Pero kung talagang kumakabig alignment na yan.
    Ipa-check mo naman dito yung mga CV joints mo...
    RIDE ON...8)8)8)
    Definitely warped rotors. After having these resurfaced, check the brake pads, as wear might be uneven and hence replacement of these is needed as well.
    Also a good time to flush out the brake fluid and use bnew ones, preferrably DOT4 or better. I suggest ATE Super Blue or ATE SL and MOTUL RBF 600.
    RS Sprint, san makakabili ng mga yan? mga how much?
    How many liters do you need ba if you want to flush the brake system?
    Sa CATS meron.
    Alam ko nanginginig talaga ang brake pedal pag may ABS kotse mo at pumpreno ka nang biglaan.
    Pa-inspect mo na rin yung brake system mo, lalo na yung brake pads at brake fluid. :D
    That's true, pero iba ang pulsing feeling ng brake pedal kapag nag activate ang ABS, at sa brake judder due to warped rotors.
    Yung pulsing caused by ABS feels weird, non mechanical whereas ang brake judder due to warped rotors feels like may masisira na sa oto mo.
    CATS is the one in greenhills? Meron pa bang ibang place na available yang mga yan? Magkano ba tong mga to? Ano ang next best after ATE and MOTUL?
    Yup, CATS is the service station in Greenhills.
    You can also try CASTROL RS brake fluid, same spec as the MOTUL RBF and ATE Super Blue. Not sure where else you can buy these. The ATE Super Blue costs about 600 per 500 ml, the RBF about 700 per 500 ml.
    You need 1 liter of brake fluid to flush out most brake systems, so go figure.
    how much naman yung castrol?
    when flushing can I use a different brake fluid first? Parang ang bigat sa bulsa pag pinamflush tong mga to.
    d ba yung clutch brake fluid din nilalagay. Is it advisable that I use na din?
    Jan 2003
    pre check this site:www.icarumba.com. surely, you wil learn a lot from this site.
braking problem
