Results 1 to 3 of 3
    recently, may ugong ako naririnig sa front left wheel lalo na pag nag slow down. After ko pinacheck ung bearing, ala naman daw alog ung gulong. Sabi pa ng mekaniko baka ung gulong at mags daw oblong. So pinagpalit ko ung gulong sa harap at likod pero may ugong pa rin. Huli ko na check ung disk brake rotor sa driver side at may nakita ko parang groove paikot sa rotor.
    Ang tanong ko po eh eto po kaya cause nung tunog sa gulong? Maisusuggest nyo na rin po ba na pa resurface ko na ung disk brake ko?
    Thanks in advance sa mga advice.
    Quote Originally Posted by magilas_316 View Post
    Have the car checked for potential problems in the following:
    -wheel bearing
    -brakes (dragging)
    If the brake pads are dragging, it might mean your just need to have your calipers cleaned and maybe new brake pads installed (if the existing pads got damaged).
    BTW, what was the last work done on your car before the problem?
    Last work done was the replacement of front brake pads. Pero bago pa palitan ng pads, naririnig ko na ung ugong. lalo lang po siya lumakas nung tumagal na.
    BTW sir, ano po ung dragging?
    Thanks ulit!
For brake resurfacing na po ba ito?
