Results 1 to 12 of 12
    mga bossings...
    ano ba mga causes ng screeching sound pag nag b brake? o kaya pag downslope ang sasakyan tapos pag nag tapak ka ng brake may unusual sounds sa brakes??
    possible worn out pads.. or do you have aftermarket pads?.. like bendix metalking(tama ba to?)... kasi some pads are harder in compound making more noise than others...
    wala namang jiggle while braking right??? nde ba nawawala pag matagal ng tumatakbo?.. palagi bang meron when brake is applied?...
    if pads are not worn out you are probably using a replacement pads with harder compounds. if you've got the oem pads then try cleaning the pads.
    yep palagi meron when the brake is applied
    saka bendix nga yun gamit ko na brake pads...
    try ko rin check cguro sa weekend kung worn out na..anyway tnx guys
    try to change your brake pads to softer ones, kaya nag-screetch yan kasi matigas yung brake pads
    Definitely worn out brake pads. Have them checked and replaced. :D
    di kaya po dahil sa may tama ung brake disc nya?
    that's why i asked kung may jiggle pag nagbebreak siya... since wala.. malamang pads lang yan.. try buying a softer compound brake pads....
    Quote Originally Posted by zildjian
    how do you clean the brake pads?
    HBOY,
    un ba effect pag may tama ung brake disc?
    paano kung sa isang side lang?
    Normal sa karamihang kotse ang squeaking ng brakes, dahilan sa friction. Kung may naririnig ka nang ibang sound, pacheck mo na preno mo. Saka pag napansin mong mas matagal nang huminto ang kotse mo, palitan mo na ang brake pads. Kailangan din siguro ng brake adjustment.
    meleagant,
    usually if your rotors are warped.. you'll have the pulsating feeling on the brake pedal when you are braking.... and at high speeds with sudden braking, your steering would jiggle as you apply the brake pressure.
    squala, normal ang squeaking?.. nde ata normal yun.. either may problema or madumi lang talaga ang pads.... ewan ko lang. i dont have squeaks when i brake in my car.:D
    if the squeak is a high pitch sound na very audible, palit ka ng brake pads.. pero kugn parang small intermittent squeaking, madumi lang yung pads...
brake question
