Results 1 to 9 of 9
    Sep 2004
    Hi to all tsikot members, tanong ko lang po kung how much pa repair ng power steering leak, Mine is a Toyota Gli '98 model medyo nag canvass na rin po ako sa talyer dito sa may P.Ocampo cor. dela rosa. mga 7K daw po repair kit (orig. toyota parts) kung OEM mga 5K including labor for both. Standard po ba yung ganitong pricing?
    JoelanP
    Nov 2003
    the repair kit sounds slightly expensive. check in casa as to the correct price. isang tawag lang katapat.
    Mar 2004
    mga 4k lang repair kit pag sa casa... pero marami nabibilhan na mga 3.5k
    Sep 2004
    yup, already called sa kasa 4k nga P1,650 nman sa labor. Oks lang ba kung bilin ko nalang sa kanila repair kit then sa kakilala ko na lang na mechanic ipakabit. but some says medyo delicate daw yung mga wirings . Thanks ulit sa mga ng reply
    Apr 2005
    pare,
    traced ba where the leak came from?if it comes from ps pump
    better to replace na lang w/ surplus pump.hanap ka lang sa
    banawe.mga 3k to 4k ang price.
    You should also check P/S hose status, minsan dun nagsisimula ang leaks bago madamay ng P/S pump. Nung nagpalit kami dati umabot ng 8k ang OEM P/S hose, di kinaya yung pressure ng locally crimped which was 1/3 of its price.
    Aug 2004
    Reasonable na yung 1650 labor sa casa. Sa Zee at sa suking mechanic ko halos same price din ang baba ng rack and pinion.
    Nov 2003
    i doubt the 1650 is for pulling down the rack. malamang they quoted you the price for overhauling the pump...
    i could be wrong pero seems more probable.
    Sep 2004
    i hope ur wrong speedyfix, i can get my car tom. sa toyota marikina, they call me yesterday and said na mga P7,400 bayaran ko since may gimamit silang panlinis sa hose but i said diba dapat kasama na sa labor yun. charge me sa repair kit P4,700 wala na daw sila nung 4K na price. so it end up na mga 6K bayaran ko tom. Tanong ko lang sa inyo how can i check na talagang pinalitan nila yung repair kit? Thanks ulit
    PS. they can't even adjust my stock alarm sobrang sensitive he dapat daw daling ko sa Toyota Cubao tama ba nman yun
power steering leak
