Page 12 of 22 FirstFirst ... 28910111213141516 ... LastLast
Results 221 to 240 of 437
    May 2017
    #221
    Aug 2008
    #222
    Quote Originally Posted by maculet View Post
    They need something Japan made. Andami nila sa nlex/sctex, traveling at supersonic speed installed f16 jet pipes.
    Sent from my Mi A2 using Tapatalk
    Methinks those Proacts are the top of the line ones. Kaso US made so probably will only cater to USDM models.
    Are those pads for your car? Which model?
    full na inbox mo bro pero surprising nga iyong mga pangyayari
    anyhow, ako i stick w/ project mu. malakas ang kagat and very minimal ang brake dust.
    ika nga ni ramon bautista, "jdm numba 1!"
    ang problema, hindi ko alam kung ok na uli sila autoplus sportzentrium after the fire that razed their shop last year. hindi ko napapansin pag napapadaan ako sa edsa if ever man mapadaan ako ng edsa.
    #224
    Quote Originally Posted by jigeloh View Post
    may nakita din ako akebono for L300 fb hehe
    #225
    i think yung sa edsa is still under (re)construction pero yun motul arm nila is in operation from a different office.
    naalala ko decade ago nagkamali ako type ng pad semi-metallic na project-mu pads. ang ingay tapos muntik pa kainin yun rotors
    #226
    sorry hindi pala mu. naalala ko na endless na pang dc2 integra semi-metallic yun kumain sa rotor ko
    #227
    Sorry bro. Ayan nagbura na ako. Literally nalaglag pa nga ako sa upuan sa gulat.
    Ganda din ng reviews ng Project MU. As for Akebono, the only experience I've had was the OEM in my D40 Navara. Little to no brake dust, progressive feel and great stopping power. Tried EBC Greenstuff and thought it was an upgrade but they were noisier, dustier and felt like it had a little less stopping power.
    #228
    Those on Project mu pads, please periodically check for a known common issue as seen on the pic. Hope Pmu has had them addressed & updated.
    May 2017
    #229
    Akebono is an OEM supplier for all the japanese car manufacturer, even for honda that also use a nissin pads in some of its model and toyota that currently uses Advics brand. Akebono also supply brake pads to Ford and GM. To become a brake pads supplier for a car manufacturer, it must pass several test for quality and safety standard. Meaning Akebono have the best quality brake pads.
    #230
    I will check mine on my next oil change. If they are bad, I will change them to Brembo.
    #231
    That's nasty
    I knew they were good but I didn't think they'd be better than EBC. EBC claims their Greenstuff is better than OEM. Maybe they're talking about another OEM supplier. Maybe EBC's Yellowstuff would do better vs the OE Akebonos but those pads are a lot more expensive.
    #232
    sorry for my naieveity. what would be the cause of the pitting?
    interesting. any links where i can read more on this bro?
    #234
    There aren't many who've PMU'd. That's an archived pic. Initially it was cast an anomaly...but repeated use & inspection on a bud's found it wasn't. This was about 5years ago. Bad batch? I hope. Corrected? I sure hope so. Just check upon every PMS. PMUs are generally bang4buck/bite.
    EBC in the early 2000s also had bad batches where pads sheared. I had 1st hand failure on Greens way back(archived pic of my rear green below, half sheared off). Retried them lately, so far, they've been w/o problems. Keeping an eye on them. Reds bite better & cleaner.
    #235
    Who couldn’t complain? I bought my Project Mu front pads for the FXT at Autoplus for only 2700. That’s way cheaper than what you will pay for at the casa.
    #236
    True...Bang4buck/bite they are, bai. Just keep an eye, fluke or not.
    Carbotech, G-Loc, Hawk are among the good ones. Dunno if locally available, tho.
    #237
    Oks naman yung bite on braking but it is noisy.
    #238
    hindi ba super mahal ng hawk?
    #239
    ah okay! nakita ko na may crack pala. hindi yung pitting. mahirap ang walang salamin hehe
    Apr 2010
    #240
    legit kaya seller sir?
Brake Pad Thread [Merged]
