Results 1 to 13 of 13
    I just had my brake discs and brake drums refaced yesterday. and also my parking brake adjusted..problem is theres this noise that i hear whenever i accelerate and halt to a stop....i tried to drive in an incline surface to test if my brakes are bonding, but the car slides down.
    btw i hear it in the back.
    It's quite hard to determine what causes the noise without hearing it actually. Baka hindi pa lang po nag set yung pads sa drums. Give it a couple of days more to fully set in the parts. And to check if the brakes are bonded, use hand to feel if rims get too hot to touch. A hot rim after driving around is normal, as long as you can hold the heat with your hands.
    will check that.. tnx sir ungas.. :D
    You're welcome. :D
    OT: And do bring your Carnival on the 31st.
    Mar 2003
    naging problema ko rin 'yan binalik ko lang sa pinagawan ko na solve naman 3 balik nga lang bago nagawa.
    Nov 2003
    baka mali or kulang yung pag-adjust ng handbrake. this will cause braking power to be weaker overall and will explain why di sya kumakapit.
    kumakapit naman po ang siya..feeling ko nga mas malakas ngyn ang brakes. yun lang may "rolling" sound pag umaandar at tumitigil. bigyan ko pa hanggang bukas pag meron pa rin ibabalik ko na lang.. tnx anyway migz :D
    Hindi kaya parating naka-contact yung pads sa rotor mo?
    Nov 2003
    or some bearings yung problem? who knows?!
    anyway, you're welcome!
    Mar 2003
    since, nagpa-refaced ka kinalas brake assembly mo malamang hindi nila naibalik nag maayos baka may sumasayad na kung ano sa brake drum ng oto mo.
    Jan 2004
    pag umingay preno maraming dahilan. puede yung brake pads mo ay manipis na, or yung back plate ng rotor mo ay nakadikit sa rotor. I am referring to a disk brake system.
    btw folks sa likod ko pa sya naririnig..left side..
    it turns out naninikit pala yung sa side na yun..ibinalik ko sa gumawa..inadjust nila...hindi na sya umiinit, hindi na rin masyadong audible yung tunog pero meron pa rin eh...lalo na pag maghahalt na yung kotse....
    eeeeeewwwwwwww ......yung tunog..hehe getz nyo ba?
    Nov 2003
    baka naman may dapat na palitan dyan na di pa ginawa. try and bring it back or get a 2nd opinion. font f%!# around with brakes. mas impt na gumana yan kaysa sa makina mo
Brake Noise
