30,000 km - 1 year and a half old - Brake fluid almost at MIN mark
1. Kailangan ba ibleed/flush?
2. Pwede bang idrain ko nalang yung nasa reservoir tapos palitan ko ng bago?
Please help.
Please help.
pa check mo brake pads kung pudpud na tulad ng sabi ni bro stock, tapos sabay mo narin bleed yung brake/clutch fluid
Probably ubos na brake pads. Replace pads muna then fill kung kulang pa din.
Nangyari sa akin ay nag top up ako. Nung pinalitan ng pads, nag overflow. Bakbak pintura ng hydrovac at sa may firewall.
That was done by an absolute incompetent.
When you reset the caliper piston back in, you open the bleeder screw and allow the displaced brake fluid to leave the caliper. never push old brake fluid back up to the master cylinder. Top the master cylinder off later when the brake pads are seated.
