Results 1 to 20 of 23
    Mga Sirs,
    How would you know if the wheel bearing starts to worn-out? What are the symptoms and how much would be the replacement cost for each (front and rear)? How critical is this part? Is it necessary to have a genuine replacement from casa or just a replacement part from car shops?. My car is 2003 Honda City. Thank you for any info you can share..
    Feb 2009
    Quote Originally Posted by restituto View Post
    Mga Sirs,
    tell tale signs include growl, knocking noise when hitting bumps, metallic scraping or the anti lock warning light turns on. when you have alignment checked, the camber is changed to a less positive or more negative camber
    Jan 2013
    maugong habang tumatakbo ang oto
    excessive vibration and bumpy ang ride.
    Sep 2012
    Quote Originally Posted by andrew_28 View Post
    To add... kapag malala na, kahit ikot mo lang free wheel habang naka jack dinig na dinig mo ugong
    thank you for the reply sirs. how about the criticality of this part? do i need to get an a replacement part from CASA which for sure the cost too much or a replacement from any auto shop will suffice the requirement. Where can I get a good quality replacement with a good price aside from CASA and magkano ba yan sirs? what brand should I consider? thanks again for the info.
    May 2011
    mura lang usually wheel bearing (below 1k i think for old cars), ang mahal yun labor - you have to pay for the hydraulic press OUT (old) and IN (new).
    kung pasimula ng palitin yan me ugong on certain speeds. Kapag malala na, ugong magdamag.
    Jun 2010
    koyo or ntn are good brands, AFAIK yan din ang OEM bearing na gamit ng honda mismo, hrc banawe specializes in honda parts I,m sure meron sila. kahit saang malalaking auto parts shop meron nyan just bring samples.
    criticality of the part? if its durog na, the wheel cannot spin anymore, dahil barado na.
    Familar kayo sa HTC brand? Yan lang nabili ko sa suki kanina, wala ma order na nsk or koyo eh, thanks!
    Sent from my SM-C900F using Tapatalk
    HTC brand din ang ipinalit ko nung nasira ang wheel bearing hub assembly sa aking 2010 civic. so far ay ayos pa naman sya.
    Ilan km na natakbo bro since installation bro? Thanks!
    nasa 80k+ odo reading sya.
    ah OK na sakin maski 40k Km lang itagal nito LOL
    thanks bro ^_^
Worn out wheel bearing?
