Results 1 to 12 of 12
    Oct 2011
    Sirs, how often do you spray your rotors with brake cleaner? sa ibang shop, liha lang ginagamit nila... advisable ba na liha lang or mas maganda kung brake cleaner gamitin?
    Feb 2009
    there is no necessity using brake parts cleaner. you can wash brake components with denatured alcohol or soap (dishwashing liquid) and water solution. using sand paper on the rotors or brake drums is just done to deglaze the surface if you install new brake pads or shoes so they break in fast. otherwise, if the drums or rotors are not oily, not glazed, not rusty, you can just wash them to remove as much oils, dust and other foreign material on the surface
    Oct 2011
    okay noted sir.
    Can you load the mix up in a hand sprayer as well?
    I use 3M brake cleaner though, every 10,000kms. Every 5K, i just inspect and spray with compressed air.
    Feb 2009
    NEVER, NEVER, NEVER use compressed air to clean brakes. you can use compressed air to dry wet brake parts from washing but NEVER use compressed air to clean dry brake friction parts. they might say the friction materials are asbestos free, but you don't know they might be more harmful than asbestos.
    you can use a hardware purchased spray bottle to wet clean the brakes with soap and water,
    That's quite possible. Thanks for the heads-up on that concern; common practice pa naman yan with most shops (even at the CASA).
    May 2011
    i used compressed air then wurth brake cleaner after.
    Regular cleaning, mas maganda syempre brake cleaner.
    Just aim and spray, bagsak lahat ng grease, grime, dirt.
    Kung liha, masisinghot mo pa ang dust baka may asbestos.
    80 petot lang yata sa Petron, same lang performance compared sa 3M or Permatex.
    Oct 2011
    80 petot lang sa petron brake cleaner? ilan ml yan? meron pala sa petron.
    never have i used commercial or home-made brake cleaners in any of my cars. that's a combined 40 car-years. and never have any of my brakes failed or needed premature replacement. yung liha lang, pinabayaan ko. trip ni mekaniko, e..
    sa init ba naman sa pag-gagamit sa brakes..
    Oct 2011
    cguro sa road condition din sir, kung madalas ka sa dusty and muddy roads maybe the more you need brake cleaners pag city driving, konting hugas lang and liha.
Brake Cleaner
