Hello Tsikot Peeps!
Muzta na kayo!
Tanong ko lang. Ano ba ang the best na brake pads for Civic? Yung medyo mura pero ok naman ang quality. Tsaka saan din po nakaka bili? Kung may alam kayo dito sa Makati mas ok. Thanks ulit!
Hello Tsikot Peeps!
Muzta na kayo!
Bendix makes a wide variety of pads for different applications. And they generally perform well.
Or you could just get boring, old OEM again. hehehe.
another quality brand is R-Spec, 2 weeks ago nagpapalit na rin ako on all 4s up to now wala naman squeeks at brake dusts akong napapansin, yun nga lang di ko type yung color niya (blue)
yup! r-specs is a good brand...had mine installed several months ago...wala naman problems like brake dust and noise...before nun, bendix ako...experienced grinding sound and heavy amounts of brake dust sa hubcaps ko...
Replacement: Bendix/Bendix Metal Kings is OK... its the metal kings that make more noise i think but it performs very well.![]()
for a civic, I bought mine at HRC at banawe mas mataas nga lang pala presyo nila compared dun sa isang post, front pads 700, rear pads at 650-Originally posted by wrecker
magkano ba r-spec and saan nakakabili?
mukhang okay nga iyang R-Spec ah...masubukan nga...
kung galit ka naman sa pera, you may go for EBC greens....
peeps!
maraming salamat sa replies! Pumunta ako ng Banawe, bale Bendix nalang binili ko. P650 ko nabili yung front pads... mahal ba yun?
Tsaka ganon ba talaga, wala ba talagang naka engrave na "Bendix" dun sa mismong bakal ng brake pads? Kasi sabi nung pinagbilhan ko Bendix daw yun... pinakita niya kahon, bendix nga. Naisip ko lang kasi baka yung kahon lang niya ang bendix pero yung mismong pads eh hindi.
Btw, magkano ang EBC Greens?
:bwahaha: ok toh ah, hahaha.Originally posted by chieffy
I'd stay away from those "semi-metallic" formula pads, it would chew your discs faster and squeek more. yun ang pads ko noon sa integra ko, nasayang lang yung slotted rotors ko.
nakabili na pala si sirpidol ng pads, ayos. EBC Greens dito is around $45.00
Okay ba ang R-Spec brake pad? Eto kasi inoffer sakin 650 pesos lang para sa isuzu bighorn. thanks
R-Spec is sufficient for daily driving. I tried them out just for kicks. The first few days hindi masyadong responsive compared sa OEM, pero pag tagal, gumaganda pedal feel.
R-spec din nakasalpak sa Starex. Ok naman for daily driving. Hindi ko naman dadalhin sa Subic Raceway or Batangas RC yung sasakyan. :lol:
bad experience sa r-spec nung nagpalit ako last year sa civic, pina machine shop ko pa yung rotor ko dahil yung old -pads kumain na. after few months nakakabit ganun din nangyarimay squeek at nagkagroove ulet yung rotor. intay ko na lang mapudpud then try ko naman mag bendix..hay
mga peeps anu ba ung OEM na nissin brake pads ng civic? kasi ung akin bgong palit plang mga 2 months lang bigla syang tumunog na sobrang lakas na squeaking sound!! prang wala ka nang brakes.. ang mas problema dito wlang brake application!! Im cruising around tpos biglang may sobrang lakas na tunog!! kala ko sa taxi ako pla!!.. pina check ko kgad sa trusty mechanic ko.. tpos sbi nia palit nlang daw ako ng pads 1K for 2 front pads na bendix.. mhal b un? ok ba ang bendix?
bendix is quite decent enough pero if you want more performance there are tanabe endless and project mu brake pads for the civic
