Results 1 to 7 of 7
    Dec 2011
    hi guys.. i am sorry for this noob question.. i dont even know if this inquiry has a sense.
    i am planning to change my tires.. i was just thinking if it is possible for me to upgrade the sidewall of my tire? like from 205/45/16 to 205/55/16?
    thanks!
    Jan 2009
    That should work. Obviously, the 55 has a taller profile than the 45 so speedometer accuracy will be slightly affected.
    Aug 2004
    That's almost an inch in height difference. Not worth it. The car won't ride any better (unless you pump the tires way down... which is dangerous) and the tires may rub the fenders over humps.
    If you're doing this for reasons of ride comfort, just buy smaller wheels.
    Jul 2011
    if the height is maintained but width is increased, what is the effect on ride comfort?
    Aug 2004
    Depends on how much wider. If it's significantly wider at the same height, then the tire is heavier and will ride worse. If it's just modestly wider (like 205 vs 195), the difference will be slight.
    Jul 2011
    how about from 175 to 195? may nag-advise kasi sa akin para mabasawan tagtag nung jazz ko ay kailangan palaparin ung gulong.
tire sidewall upgrade?
