Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jul 2012
    sir according to my trusted mechanic i need to replace wheel bearing - kasi maingay na, and lower suspension assembly kasi crack na raw yung rubber bushing ng honda jazz 2005 ko. where nyo po ma recommend pumunta na mura at maayos gumawa.
    bandang south area po ako.. laspinas, alabang, laguna area po sana. ok kaya sa minerva alabang? maayos po ba dun at mura? thanks!
    sa south.... there are recommended suspension shops that i can give:
    Servitek Alabang, Minerva Tires and Customer's Cradle.... Lahat yan nasubukan ko na and lahat naman maayos gumawa.
    Servitek Alabang, Minerva Tires and Customer's Cradle Las Pinas.... Lahat yan nasubukan ko na and lahat naman maayos gumawa.
    agree ako sa customer's cradle las pinas
    naka-try na ko pagawa ng pang-ilalim sa kanila at satisfied ako sa gawa nila
    bili ka na lang ng pyesa sa suki mong parts shop tapos dun mo na lang padali. masmakatipid ka pag ganyan bro
    Jul 2012
    thanks sa reply.. pwede ba pacheck mo muna sa kanila then sibat to buy part sa ibang shop then balik sa kanila to install parts? wheel bearing sana need ko palitan and eventually yung lower suspension assembly ng honda jazz.. hindi pala nabibili yung bushing lang eh.
    Jul 2012
    question po.. pag sinabing wheel bearing.. iba iba un? may kaso ba kung may "ABS" yung sasakyan or wala? thanks!
    Quote Originally Posted by nashimoto View Post
    Sa casa, buong lower arm assembly. Pero may nabibiling bushing lang sa mga shops. Ipapa "machine shop" mo lang para mapalitan yung bushing.
    Meron ding nagpafabricate ng mga bushings.
    Jul 2012
    sir panu po yung wheel bearings? iba ba ang bearing ng may ABS sa wala?
    Di ko alam kung magkaiba. Most probably pareho lang.
    Sabihan mo na lang yung shop na pagkukuhanan mo na ibabalik mo kung mali.
    pareho lang ang bearings..... the ABS is installed dun sa may joints.... labas yun ng bearings.... ang bearings nasa loob ng axle.
    Jul 2012
    ah ok.. so regardless kung may ABS or wala oto mo, wheel bearings are all the same? Yung make and model na lang ng sasakyan ang dapat itake consideration?
    Jul 2012
    Quote Originally Posted by 1D4LV View Post
    so far minerva pa lang na try ko for wheel alignment and change oil. bisita nlng siguro ako. libre naman check up dun diba mga sir? diko kasi alam kung anu tlga issue sa suspension ko eh.
    yup. correct.
    yup. correct.
    Jul 2012
    sa alabang minerva kaya may wheel bearing for jass or buy muna ako part? gusto ko rin muna pa check bka hindi yun ang sira eh.
    much better if you bring the car there, have it diagnosed properly and replace parts.
    kung may parts sila dun, di dun ka na kumuha... otherwise, kung namamahalan ka sa parts nila, then ikaw ang bumili.
    it would be very hard for us to actually specify kung may parts dun yung sasakyan mo.... all i can say is yung experience ko lang..... they have parts there for mitsus and toyotas (nung nagpagawa ako sa kanila). dunno of the jazz.
    Yun sensor ng ABS sinasabi niya, Kung lahat ng model ng Jazz meron abs then walang problema dahil Isang klaseng replacement part Lang na wheel bearing but if there are two models ng Jazz one with abs and the other with out, doon May problema make sure makukuha mo yun para sa may abs, Kung hinde iilaw yan.parang magnet yun dulo ng abs sensor nakadikit siya sa bearing Sa labas
    Jul 2012
    thanks shadow.. yun nga po ang ni explain sakin nung mekanino na kilala ko.. pa check ko nlng sa minerva.. sna hindi ganun kamahal ang bearing for abs.. may abs kasi yung jazz ko.
best suspension repair shop for honda jazz
