Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Oct 2003
    Tanong ko lang dun sa nagpalit na ng aftermarket steering wheel-may advantage ba ito o purely pogi points lang ng oto?
    Thanks!
    One advantage if you get one with a smaller diameter is the decreased size makes steering with both hands easier. I also like the feel much more than the OEM ones.
    If you get an aftermarket wheel, Momo is still the weapon of choice... followed by Sparco. They may seem pricey at first but you can take this with you even as youi change rides.
    If you drive a sedan you usually cant go wrong with a Momo Race.
    Kung SUV, Momo Club4.
    Bad trip kasi may airbag yung auto ko kaya di ko mapalitan.
    Oct 2003
    pajerokid,simple lang ba ang installation nito?wala namang airbag yung sedan na paglalagyan ko.
    Jan 2003
    diba kung mas maliit ang steering wheel mas maraming ikot ikot as compared to the larger stock ones? or since club4 naman medyo malapit na sa stock? :D
    madali lang kabit yan.. bili lang ng boss kit sa suking tindahan sa banawe tapos sabihin sa tindero, " pakabit naman please.
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    shintaro, nakupo ser, 30 minutes tapos ang installation niyan. On the question of function, in a way meron naman kaunting advantage. For me personally, i miss the momo's comfort (thicker) and ease of use of the horn button.
    Noteworthy, nope. pareho lang number of turns, kaya lang, mas maliit yung radius ng turn, if you replace the default steering with a smaller one.
    ako rin..mas comfortable hawakan yung momo kesa sa stock..
    for me, its a good investment kasi its right in front of you, nahahawakan pa..pogi pa.
    Oct 2003
    Yup ganda yung Club4, kahit sa sedan k din.... (",)
    Jan 2003
    so the turning radius will definitely get smaller? is there a slightly larger diameter? :D
    notEworthy27, turning radius will be the same. what it would change is the 'time and effort' to turn your steering wheel.
    I got confused with this question. I tried to rephrase it myself but the question still doesnt make any sense.
    Did you mean to ask:
    is it slightly larger in diameter?
    is there any steering wheel which is slightly larger in diameter?
    smaller diameter: faster to turn/steer
    bigger diameter: slower to turn/steer
    To change the 'actual' turning radius of a vehicle, you will be needing an aftermarket Rack & Pinion assembly.
    PK, pwedeng palitan kahit may SRS.
    di ko yata pwedeng sabihin to ah Momo stock steering wheel ko eh, pero the diameter is still too big. :waah:
    Jan 1970
    just want to add:
    smaller diameter: faster to turn/steer = less effort/arm torque to turn
    bigger diameter: slower to turn/steer = more effort/arm torque to turn
    Originally posted by t35ticles
    just want to add:
    I thought its the other way around, yes?
    smaller diameter: faster to turn/steer = more effort/arm torque to turn
    bigger diameter: slower to turn/steer = less effort/arm torque to turn
    Why? Look at those big trucks, bigger steering wheel=less effort to turn but it takes time to turn/steer.
    A smaller steering wheel travels shorter in distance. Having said that, a 'greater force' (effort) is exerted over a shorter distance (smaller diameter.)
    A 'lesser force' (effort) is exerted over a longer distance (bigger diameter) when the steering wheel is turned. (Big Trucks)
    Hehe. We're confusing ourselves mga pre. Dalawa kasi yung diameter na pinaguusapan natin. The diameter of the wheel thickness and the diameter of the wheel itself.
    Kards, ang lufet talaga ng Subaru mo Alam ko may nilalagay na resistor dun sa airbag circuit para hindi umilaw yung SRS light. I cant wait to have a Club4 again.
    ah eh pk, pede ba yan OEM steering wheel mo sa strada ko?
    reserve kung pede pards
    Pwede, kaya lang papa-reupholster ko na lang. Sayang din kasi yung Airbag pareng Kim. Nakita ko yung manibela ni Alfred, nagbago isip ko kasi ang ganda talaga ng workmanship, parang Momo yung stiching. Went there this morning kaya lang sarado.
    A bigger steering wheel will turn the front wheels slower but will require less effort. Kaya nga nung araw higante ang manibela ng mga sasakyan kasi wala pang power steering.
    i used to have a smaller steering wheel..when i replaced it with a MoMo Club4 parang nagkaron ng difference sa pagbalik ng turnsignal lever..i mean konting liko hindi bumabalik so manually ko na lang binabalik,unlike when i was still using a smaller steering wheel..is it the steering wheel or may iba pang nagalaw when i replaced it?
    higante, :bwahaha:
    hmmm, anyone has any issues like yamyam? parang weird na hindi na gumana ulit yung turn signal lever nya ah.
    Jan 2003
    sir karding, i was pertaining to the diameter of the steering wheel hehe soory ang labo ko :D
    hmmm.... hehe cge I'll go for the steering wheel whose diameter is a bit smaller than stock. hehe :D
Aftermarket Steering wheel?
