Results 1 to 8 of 8
    May 2005
    napapalitan ba ang bearing ng power steering pump? medyo maingay na eh.
    Feb 2009
    Quote Originally Posted by Asus700 View Post
    asus,
    there are three possible reasons for your power steering to make noise;
    a. growling- the system probably has low oil level or wrong type of p/s
    fluid or is foaming
    b. grinding- the bearing is going bad from the p/s belt adjusted too tight
    or simply needs to be retired
    c. if it is that of the sliding vane type pump (99% of the p/s pumps in a
    car), it might have created a wear pattern on the housing
    from using the wrong type fluid or running them low for an
    extended period sometime.
    sure the bearing can be replaced, just replace the oil seal too while you're
    at it (MAW- might as well), then flush the system and
    replenish with new compatible oil (be careful, honda and acura
    are very particular of their own or compatible oil, using any
    other oils destroys the seals and the hoses)
    jick
    instructor
    guam community college
    May 2005
    thanks for the reply jick.
    its only noisy in the morning after starting the engine and then after a few minutes it goes away.
    there is no noise when i steer or use the car.
    Feb 2009
    asus,
    so it has morning sickness, your car might be pregnant, hehehehehe.
    drain and change the power steering fluid with a factory recommended fluid. it' probably contaminated. then bleed the system by suspending the front wheels while turning the steering wheel left to right or right to left and repeat until there's a change in the noise level. not doing this causes cavitation of the pump and makes this noise. prolonged cavitation damages the pump innards
    jick
    May 2005
    thanks for the input prof. jick
    Asus
    ano naging solution sa PS pump mo? kasi ganito rin ang problema o pag umaga or malamig ang panahon medyo merong langitgit galing sa ps pump, at pag tagal na or uminit na makina wala na, car ay vti 96
Bearing of power steering pump
