Results 1 to 7 of 7
- Jun 2008
- 20
November 29th, 2008 06:03 PM #1Gud day guys,
Tanong ko lang kung shocks kaya ang sira ng auto ko o Coil spring ???
Matandq ana kse ang auto ko 1993 Nissan JX, yung rear ang problema ko kse matagtag na sya at di na nag lalaro, pag napadaan ako kahit sa maliit lang na lubak ramdam na ramdam talaga at pag sa humps bumabagsak yung rear part at pag inuga mo sya sa likod halos ayaw na umuga or may play matigas na.
Dahil tight ang budget ko , gusto ko muna malaman kung alin ang sira bago ako magpagawa or gumastos, wala pa naman akong kilkalang trusted na gagawa non baka kung anu ano ang papalitan ns hindi pa naman dapat.
Isa pa nag canvass ako ng shocks na para don b13 rear yung brand new na KYB 2.5 k each, yung surplus 1k each kso walang warranty, rebuild naman sa Cruven or Zee ay aabot ng 1.3k each pero w/ 1 year warranty, ewan ko lang ang spring wala pa ako idea kung magkano, tight talaga budget ko mga bro, di ko na lang talaga matiis ang kalabog ng auto ko sa rear e.
Hope to hear your ideas para maayos tong auto ko ng di masyadong masakit sa bulsa.
THANK YOU mga bossing !!!
November 29th, 2008 10:58 PM #2
Forget surplus. Buy brand new shocks. Surplus shocks won't last long before they blow.
If the rear is sagging, it's a safe bet your springs are soft, too.
November 30th, 2008 12:08 AM #3
1. The coil springs hardly go bad. They either break or the rubbers on the top and bottom get broken or splayed out. In the later case you simply change the rubbers. If a spring droops a little bit it can be adjusted by using a spacer to get an even height on all 4 wheels.
2. The suspension geometry differs from car to car. All have a balance, with heights varying from one make to another and the set up as per the performance required from the car.
3. According to your description, the shocks seem to be worn out and would need replacement. All the symptoms point in this direction. With new shocks, your height may even come up very slightly and your complaint about driving over uneven/rough roads will also be rectified.
Go ahead and change your shocks, guarantee it will sove that annoying bumpy ride.
November 30th, 2008 12:19 AM #4
yup, tama si Niky. forget surplus shocks..
sayang lang. get some decent shocks and have your rubbers checked.
- Jun 2008
- 20
November 30th, 2008 10:11 AM #5hello guys !!!
Thank you for all your nice and clear reply, i will now look for a brands new shocks, probably KYB or Tokico kse sila lang ata ang kakayanin ng budget ko atleast 2.3 - 2.5 each + Labor pa, so around 6k ang magagastos dito, psensya na kyo very tight talaga budget ko e.
Pro kung me iba pa kayong alam na ibang brand na mas mura pa sana mas ok, bihira ko lang naman magamit ang car ko once a week lang pagpunta lang sa mall w/ my family.
Thank you very much again to all of you !!!
November 30th, 2008 10:19 AM #6
pag basa shocks yun sigurado.
coils masisira lang pag pinabayaan mong sira ang shocks..
dont forget to camber-align and balance your tires too after the replacement.
- Jul 2003
- 573
November 30th, 2008 03:54 PM #7setter11,
1. Coil spring can either get broken or becomes compressed permanently due
to long term use and excessive load
2. shocks can also becomes to soft if there is a fluid leak.
3. shocks can also become to stiff or harder than when it was new
4. when viewed from the front or rear of the car, is your car still leveled? if so, then you don't have to change your coil spring. change your shocks and also the shock insulator/mounting on the chassis. there is also a bumper installed on the shaft of the shock absorber, replace if damaged.
