i have an L3... the prob is the car falls to the left whenever I would let-go of the steering during driving...
so i went to servitek..suggested to wheel aligment and balancing...
after check up, some worn out parts were replaced (bolt joints, idler arm bushing, draglink assembly) and had the L3 balance and aligned....
but then, the prob still exists... now the servitek crew doesn't know what to do next except guessing... baka raw may konting dikit sa brakes, old tires (need replacements na raw) etc...
first step pa check mo ang gulong mo baka uneven wear,oblong,pressure at mga pang ilalim baka meron na kailangan palitan pag tapos na baka kailangan pa wheel/camber alignment ka na rin.
if you are from the south of manila, I suggest to bring your ride to Shell Customer Cradle along Zapote Alabang Road, fronting PHCRMC.
thay have good technicians there and good equipment to verify wheel alignment before doing anything else.
